I am getting a strange result when using HTTP_req
0136.00 dcl-s RESULTS varchar(1600000) ;
0436.00 rc = http_req( 'POST'
0437.00 :'https://wwwcie.ups.com/security/v1/oauth/token'
0438.00 : *omit
0439.00 : resultS // String to receive the results
0440.00 : *omit
0441.00 : 'grant_type=client_credentials'
0442.00 : 'application/x-www-form-urlencoded');
When i look at the string results and compare it to the data that came back into my log on the ifs. The results string is shorter than the string I see in the log file. The field , results only is 1021 where the field in the log is 1481. The log shows I am successful in obtaining the token.
r Browse : /home/mydebuglog.txt
Record : 115 of 132 by 18 Column : 1 1481 by 31
Control :
....+....1....+....2....+....3....+....4....+....5....+....6....+....7....+....8....+....9....+....0....+....1....+....2....+....3.
Connection: keep-alive
Server-Timing: cdn-cache; desc=MISS
Server-Timing: edge; dur=6
Server-Timing: origin; dur=301
ak-grn-1: 0.05931ab8.1714408008.28d4634b
Strict-Transport-Security: max-age=31536000 ; includeSubDomains
Server-Timing: ak_p; desc="1714408008841_3088749317_685007691_30717_7775_59_76_-";dur=1
recvresp(): end with 200
recvdoc parms: identity 1481
recvdoc(): Receiving 1481 bytes.
{"token_type":"Bearer","issued_at":"1714408009193","client_id":"TyC9QTHSNd8JG9m4Nwg6HfAFKgAg150zVPVfqvELbaQANyg0","access_token":"ey
F3=Exit F10=Display Hex F12=Cancel F15=Services F16=Repeat find F19=Left F20=Right
Any help wiil be greatly appreciated
thanks
Bruce
OUATH2
Re: OUATH2
How did you come to the conclusion that you've only received 1021?
The ILE Debugger in the operating system will, by default, only show 1024 characters. I could see how you might confuse that for only receiving 1021 (with a slight miscount) characters. Could that be what you're seeing?
The only other thing I can think to check is the size of your variable.
Re: OUATH2
Thank you for your quick response. I have been programming for a long time but was unaware of the ILE debugger constraint of 1024 characters.
661 'TQ0OTIxMDksImlhdCI6MTcxNDQ3NzcwOSwianRpIjoiNzJjNWNlZmMtNDdiM'
721 'S00MzFlLWExNmEtMTVkMzU1Nzc3OTNlIn0.DnnM8Wzw3N25VlZ8brVVsAhF4'
781 '3LqpkuU7u8dpPA8FRVi6O5e6Jd9-FQcqlPn_9lLh1yFToNMpPn4G4ASZ8F5t'
841 'nbJn8IOBG2teb9bUWLD4PEgklEZAYa7Gkm-o5ZSGmc7CUAAU8_mwjzik_iMn'
901 'm4vyjThqdSNJue2f8N_eQaDIodMbxAL5qF_Ak4ufKcWH36Lbkp36Qq9mADfM'
961 'y5FB8F9kUT7SL-9dCJUmLbqXzyOa_hFa6-w4JtdegUTB1rdjFUe7592vQeNz'
1021 'G0xd'
Up until this spot (1024) the token is correct. My result field size is large enough to hold the token value.
Thank you once again for your help
1021 'G0xd'
Re: OUATH2
As far as I can tell there isn't a problem, here.
If you want to see the whole string in the green-screen debugger, you can type this at the debuggger's command line:
That will show 1483 bytes of the variable. (Keep in mind that a VARCHAR variable starts with either 2 or 4 bytes for the length of the data)
eval MY-VARIABLE:C 1483
Re: OUATH2
My initial issue obtaining the token seems to have been resolved. I modified example 16 to get tracking information from UPS using the token rather than license, userid/ and password. I am now getting the following error: It looks like the program may not be reading the post correctly. If anyone has some input I sure would appreciate it.
(GSKit) I/O: Broken pipe.
ssl_error(406): (GSKit) I/O: Broken pipe.
SetError() #55: CommSSL_BlockWrite: send: (GSKit) I/O: Broken pipe.
Below is part of my code:
http_xproc( HTTP_POINT_ADDL_HEADER: %paddr(AddHeader) );
postData =
'<?xml version="1.0"?>'
'<TrackRequest xml:lang="en-US">'
'<Request>'
'<TransactionReference>'
'<CustomerContext>'
'TRACKING TEST'
'</CustomerContext>'
'<XpciVersion>1.0001</XpciVersion>'
'</TransactionReference>'
'<RequestAction>Track</RequestAction>'
'<RequestOption>activity</RequestOption>'
'</Request>'
'<TrackingNumber>' + TrackingNo + '</TrackingNumber>'
'</TrackRequest>' ;
EVAL ACT = 0 ;
rc = http_url_post_xml('https://onlinetools.ups.com/ups.app/xml/Track
: %addr(postData) + 2
: %len(postData)
: %paddr(StartOfElement)
: %paddr(EndOfElement)
: *NULL) ;
if (rc <> 1);
scmsg = http_error();
// FIXME: REPORT ERROR TO USER
dcl-proc AddHeader ;
dcl-pi *n;
headers varchar(32767);
Headers = 'Authorization: Bearer' + ' ' +
a_token + CRLF +
'Content-Type : application/x-www-form-urlencoded' + CRLF;
END-PROC addHeader ;
P StartOfElement B
D StartOfElement PI
D UserData * value
D depth 10I 0 value
D name 1024A varying const
D path 24576A varying const
D attrs * dim(32767)
D const options(*varsize)
/free
if path = '/TrackResponse/Shipment/Package' and name='Activity';
act = act + 1;
/end-free
P E
P EndOfElement B
D EndOfElement PI
D UserData * value
D depth 10I 0 value
D value 65535A varying const
/free
select;
when path = '/TrackResponse/Shipment/Package/Activity';
select;
when name = 'Date';
activity.Date(act) = value;
when name = 'Time';
activity.Time(act) = value;
endsl;
when path = '/TrackResponse/Shipment/Package/Activity' +
'/ActivityLocation';
select;
when name = 'Description';
activity.Desc(act) = value;
when name = 'SignedForByName';
activity.SignedBy(act) = value;
endsl;
'/ActivityLocation/Address';
select;
when name = 'City';
activity.City(act) = value;
when name = 'StateProvinceCode';
activity.State(act) = value;
endsl;
'/Status/StatusType';
if name = 'Description';
activity.Status(act) = value;
endsl;
/end-free
P E
postData =
'<Request>'
'<CustomerContext>'
'TRACKING TEST'
'</Request>'
'</TrackRequest>' ;
EVAL ACT = 0 ;
: %len(postData)
: *NULL) ;
if (rc <> 1);
dcl-pi *n;
a_token + CRLF +
P StartOfElement B
D StartOfElement PI
D UserData * value
D depth 10I 0 value
/free
act = act + 1;
/end-free
P E
P EndOfElement B
D EndOfElement PI
D UserData * value
D depth 10I 0 value
/free
select;
select;
when name = 'Date';
when name = 'Time';
endsl;
select;
endsl;
select;
when name = 'City';
endsl;
endsl;
/end-free
P E
Re: OUATH2
Broken pipe means its trying to send more data after the network has disconnected.
Most likely, this is a network error not a programming error. Why are you getting disconnected?
Re: OUATH2
I did rerun my request this morning and received a different message.
<?xml version="1.0"?><TrackRequest xml:lang="en-US"><Request><TransactionReference><CustomerContext>TRACKING TEST</CustomerContext><
<XpciVersion>1.0001</XpciVersion></TransactionReference><RequestAction>Track</RequestAction><RequestOption>activity</RequestOption><
</Request><TrackingNumber>1Z9627AW0310393753</TrackingNumber></TrackRequest>
HTTP/1.1 400 Bad Request
Mime-Version: 1.0
Content-Type: text/html
Content-Length: 282
Expires: Fri, 10 May 2024 12:12:11 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Fri, 10 May 2024 12:12:11 GMT
Connection: close
ak-grn-1: 0.8697c017.1715343131.2358d902
recvresp(): end with 400
recvdoc parms: identity 282
recvdoc(): Receiving 282 bytes.
<HTML><HEAD><TITLE>Error</TITLE></HEAD><BODY>
An error occurred while processing your request.<p>
Reference #166.8697c017.1715343131.2358d902
<P>https://errors.edgesuite.net/166.8697c017.1715343131.2358d902</P>
</BODY></HTML>
Mime-Version: 1.0
Content-Length: 282
Pragma: no-cache
Connection: close
</BODY></HTML>
Re: OUATH2
You are receiving the error "bad request", which indicates something is wrong with what you're sending.
From what you posted here, your document isn't valid XML. There are stray < characters at the end of some of the lines.
Keep in mind, though, that I can only really help you with HTTPAPI. I can't help you with specific APIs... I'd have to research them and learn them to help. I can offer you consulting services if you'd like that sort of help, but assuming your plan is to do it yourself, you'll need to learn what the API requires and troubleshoot problems.
Re: OUATH2
is there a way to change the HTTP_TIMEOUT from the default? I am trying to go through debug but the connections times out before I can see what is wrong with my post. I tried this but, I don't think it worked as it timed out.
http_setOption('timeout': '600');
POST /api/ups.app/xml/Track HTTP/1.1██Host: onlinetools.ups.
com██User-Agent: http-api/1.45██Content-Type: text/xml██Cont
ent-Length: 305██
ent-Length: 305██
