Error code HTTP
OlivierPierre04
Error code HTTP
Post by OlivierPierre04 »
Hi folks ,
Why the return value http_error does not contain the true http error value such as 200 , 500 ... etc
** Invalid URL format
HTTP_BADURL C CONST(1)
** Host not found (not a valid IP address, or DNS lookup failed)
HTTP_HOSTNF C CONST(2)
** Unable to create a new socket
HTTP_SOCERR C CONST(4)
** Error when connecting to server
HTTP_BADCNN C CONST(6)
** Timeout when connecting to server
HTTP_CNNTIMO C CONST(7)
** HTTP response code logged (not an error, per se)
HTTP_RESP C CONST(13)
** Error calling user-specified procedure in the
** recvdoc() procedure. (user proc must return full count)
HTTP_RDWERR C CONST(16)
** Unsupported transfer-encoding value
HTTP_XFRENC C CONST(20)
** Error opening file to save data into.
HTTP_FDOPEN C CONST(22)
* Problem with the Application ID for the DCM
HTTP_GSKAPPID C CONST(23)
* Error setting auth type
HTTP_GSKATYP C CONST(24)
* Error initializing GSKit environment
HTTP_GSKENVI C CONST(25)
* Error opening GSKit environment
HTTP_GSKENVO C CONST(26)
* Error setting session type (client | server | server_auth)
HTTP_GSKSTYP C CONST(27)
* Error registering application w/DCM
HTTP_REGERR C CONST(28)
* Error open secure socket
HTTP_SSOPEN C CONST(29)
* Error setting SSL numeric file descriptor
HTTP_SSSNFD C CONST(30)
* Error setting SSL numeric timeout value
HTTP_SSSNTO C CONST(31)
** SSL handshake timed out
HTTP_SSTIMO C CONST(32)
** This app is not registered with digital cert mgr
HTTP_NOTREG C CONST(35)
** This URI needs authorization (user/pass)
HTTP_NDAUTH C CONST(36)
** Invalid HTTP authentication type
HTTP_ATHTYP C CONST(37)
** Error in value of an HTTP authentication string
HTTP_ATHVAL C CONST(38)
** Server didn't ask for authorizatin
HTTP_NOAUTH C CONST(39)
** blockread() timed out waiting for more data
HTTP_BRTIME C CONST(43)
** blockread() error during recv() call
HTTP_BRRECV C CONST(44)
** blockread() error during select() call
HTTP_BRSELE C CONST(45)
** recvchunk() did not get the trailing CRLF chars
HTTP_RDCRLF C CONST(46)
* Invalid exit point registered with HTTP_Xproc()
HTTP_BADPNT C CONST(47)
* Error retrieving SSL protocol
HTTP_SSPROT C CONST(48)
* Unknown SSL protocol
HTTP_SSPUNK C CONST(49)
* Error setting SSL protocol
HTTP_SSPSET C CONST(50)
* Out of memory
HTTP_NOMEM C CONST(51)
* Must give data in order to encode it
HTTP_NODATA C CONST(52)
* Pointer is invalid or already freed
HTTP_INVPTR C CONST(53)
* Not enough space to add encoded variable
HTTP_NOSPAC C CONST(54)
* Error calling send() API in BlockWrite()
HTTP_BWSEND C CONST(55)
** Error calling select() API in BlockWrite()
HTTP_BWSELE C CONST(56)
** Timeout waiting to send in BlockWrite()
HTTP_BWTIME C CONST(57)
** Lineread() had problem with recv() API
HTTP_LRRECV C CONST(58)
** Lineread() had problem with select() API
HTTP_LRSELE C CONST(59)
** Lineread() had timeout
HTTP_LRTIME C CONST(60)
** Procedure is no longer supported
HTTP_NOTSUPP C CONST(61)
** No communication driver defined
HTTP_NOCDRIV C CONST(62)
** Timeout sending data in blockwrite
HTTP_BWTIMO C CONST(63)
HTTP_SWCERR C CONST(64)
HTTP_FDSTAT C CONST(65)
* Error parsing XML data
HTTP_XMLERR C CONST(66)
* Error opening IFS file
HTTP_IFOPEN C CONST(67)
* Error with SSL keyring
HTTP_GSKKEYF C CONST(68)
* Must Use Table / Must not Use Table
HTTP_MUTABLE C CONST(69)
* Cookie file cant be written
HTTP_CKDUMP C CONST(70)
* Cookie file cant be read
HTTP_CKOPEN C CONST(71)
* Can't get stats on cookie file
HTTP_CKSTAT C CONST(72)
* Error converting CCSIDs
HTTP_CONVERR C CONST(73)
** Error setting stream file CCSID
HTTP_SETATTR C CONST(74)
** This Proxy server needs authorization (user/pass)
HTTP_PXNDAUTH C CONST(75)
** XML callback switched illegally
HTTP_ILLSWC C CONST(76)
** Error getting certificate info
HTTP_SSLGCI C CONST(77)
** Error from certificate validation callback
HTTP_SSLVAL C CONST(78)
** Error setting TLS versions
HTTP_TLSSET C CONST(79)
** Error with a Reader/Writer
HTTP_BAD_RDWR C CONST(80)
** Invalid HTTP_setAuth password parameter data type
HTTP_ATHPDT C CONST(81)
Re: Error code HTTP
The codes you see in HTTPAPI are HTTPAPI's error codes.
Those codes (200, 500, etc) are not "error codes" they are HTTP status codes, and are part of a well established standard. These do not come from HTTPAPI, they are sent over the network from the server it is communicating with.
