DATA-INTO Failing (Different Issue)
emhill
Post by emhill »
I had this issue with one program and thanks to JonBoy49 was able to get past it. I'm now getting the same error but it has a little different twist to it.
I'm using a handler due to the size of the incoming JSON. Here is my DS:
dcl-ds REPAIRINGOUTLETRECORD_t qualified template;
  REPAIRINGOUTLETBUSINESSPARTNERCODE varchar(10) inz('');
  REPAIRINGOUTLETNAME varchar(30) inz('');
  REPAIRINGOUTLETADDRESSLINE1 varchar(30) inz('');
  REPAIRINGOUTLETCITY varchar(18) inz('');
  REPAIRINGOUTLETSTATE varchar(2) inz('');
  REPAIRINGOUTLETCOUNTRY varchar(2) inz('');
  REPAIRINGOUTLETPOSTALCODE varchar(10) inz('');
  KILOMETERINDICATOR varchar(2) inz('');
  CURRENTLABORRATE packed(9:2) inz(0);
  CURRENTLABORRATEEFFECTIVEDATE varchar(10) inz('');
  CURRENTTRAVELDISTANCEREIMBURSEMENTRATE packed(9:2) inz(0);
  CURRENTTRAVELDISTANCEREIMBURSEMENTRATEEFFECTIVEDATE varchar(10)
      INZ(' ');
  CURRENTLANDEDCOSTMARKUP packed(9:2) inz(0);
  CURRENTLANDEDCOSTMARKUPEFFECTIVEDATE varchar(10) inz('');
  num_CLAIMPROCESSEDRECORD int(10) inz(0);
  dcl-ds CLAIMPROCESSEDRECORD dim(100);
    TRACKINGNUMBER varchar(10) inz('');
    REPAIRORDERNUMBER varchar(8) inz('');
    PRODUCTSERIALNUMBER varchar(20) inz('');
    CLAIMNUMBER varchar(20) inz('');
    MODELNUMBER varchar(15) inz('');
    REPAIRORDEROPENDATE varchar(10) inz('');
    DELIVERYDATE varchar(10) inz('');
    PRIMARYFAILEDPARTNAME varchar(25) inz('');
    PRIMARYFAILEDPARTNUMBER varchar(20) inz('');
    CLAIMSTATUSCODE varchar(3) inz('');
    CLAIMSTATUSCODEDESCRIPTION varchar(20) inz('');
    CLAIMTYPE varchar(2) inz('');
    EXCHANGERATE varchar(10) inz('');
    PREVIOUSCREDITAMOUNT packed(10:2) inz(0);
    PARTCREDITTOTAL packed(9:2) inz(0);
    PARTMARKUPTOTAL packed(9:2) inz(0);
    LABORCREDITTOTAL packed(10:2) inz(0);
    NETITEMCREDITTOTAL packed(9:2) inz(0);
    NETTOTALCREDITDOLLARS packed(9: 2) inz(0);
    REQUESTEDTOTALDOLLARS packed(9: 2) inz(0);
    DIFFERENCETOTALDOLLARS packed(9: 2) inz(0);
    DOCUMENTNUMBER varchar(20) inz('');
    num_CLAIMLINEDETAILRECORD int(10) inz(0);
    dcl-ds CLAIMLINEDETAILRECORD dim(150);
      APPROVEDQUANTITY packed(5:1) inz(0);
      REPLACEDPARTNUMBER varchar(15) inz('');
      PARTNAME varchar(1) inz('');
      LABOROPERATIONCODE varchar(8) inz('');
      PARTLANDEDMARKUP packed(9:2) inz(0);
      NETITEMCODE varchar(10) inz('');
      PRORATE packed(9:2) inz(0);
      TYPE varchar(10) inz('');
      GROSSCREDIT packed(9:2) inz(0);
      TOTALCREDIT packed(9:2) inz(0);
      PROCESSCODE varchar(10) inz('');
      PROCESSMESSAGE varchar(80) inz('');
And here is the data-into:
options = 'doc=file case=convert countprefix=num_ allowextra=yes ' +
          'path=jsonDoc/CREDITADVICEHEADER/REPAIRINGOUTLETRECORD';
data-into %Handler( processRepairOutletRecord : totalItems )
          %DATA( ifsPathname : options )
          %PARSER( 'YAJLINTO'
                 : '{ "document_name": "jsonDoc", +
                      "number_prefix": "YAJL_" }');
The program works great until it gets to a certain point in the JSON. This is a scaled down version of the JSON. It will process through
repairingoutletbusinesspartnercode of 0322400401. Then it will give me the error below (shown after the JSON) when it hits 0322400600 partner code:
  "creditAdviceHeader": {
    "creditAdviceNumber": "202202",
    "distributorCode": "03224",
    "creditAdvicePreparationDate": "2022-01-11T15:47:02.122Z",
    "repairingOutletRecord": [
        "repairingOutletBusinessPartnerCode": "0322400400",
        "repairingOutletName": "Freightliner of Philadelphia",
        "repairingOutletAddressline1": "11 Runway Road",
        "repairingOutletCity": "Philadelphia",
        "repairingOutletState": "PA",
        "repairingOutletCountry": "US",
        "repairingOutletPostalcode": "19057",
        "kilometerIndicator": "Mi",
        "currentLaborRate": "155.0",
        "currentLaborRateEffectiveDate": "2020-01-06",
        "currentTravelDistanceReimbursementRate": "1.0",
        "currentTravelDistanceReimbursementRateEffectiveDate": "2011-08-30",
        "currentLandedCostMarkup": 0,
        "currentLandedCostMarkupEffectiveDate": "2020-01-06",
        "workInProgressClaimsRecord": [
        "workInProgressETCRecord": [
        "etcRegistrationRecord": [
        "claimProcessedRecord": [
        "repairingOutletBusinessPartnerCode": "0322400401",
        "repairingOutletName": "Freightliner of Lancaster",
        "repairingOutletAddressline1": "1675 Rohrerstown Road",
        "repairingOutletCity": "Lancaster",
        "repairingOutletPostalcode": "17601",
        "currentLaborRate": "135.0",
        "currentLaborRateEffectiveDate": "2017-08-08",
        "currentTravelDistanceReimbursementRateEffectiveDate": "2011-11-27",
        "currentLandedCostMarkupEffectiveDate": "2018-05-17",
            "trackingNumber": "225704",
            "repairOrderNumber": "225704",
            "claimType": "01",
            "productSerialNumber": "6511643920",
            "claimNumber": "AT0493763",
            "dispositionCode": "",
            "dispositionCodeDescription": "",
            "requestedDollars": 271.74
            "trackingNumber": "226159",
            "repairOrderNumber": "226158",
            "claimType": "01",
            "productSerialNumber": "6511403589",
            "claimNumber": "AT0494714",
            "requestedDollars": 288.16
            "trackingNumber": "102623",
            "repairOrderNumber": "102623",
            "claimType": "01",
            "productSerialNumber": "9630047747",
            "claimNumber": "AT0494295",
            "requestedDollars": 4008.31
            "trackingNumber": "821627",
            "repairOrderNumber": "821627",
            "claimType": "01",
            "productSerialNumber": "6311963167",
            "claimNumber": "AT0494321",
            "requestedDollars": 692.17
            "trackingNumber": "226464",
            "repairOrderNumber": "226464",
            "productSerialNumber": "6311819179",
            "claimNumber": "AT0492161",
            "modelNumber": "2100HS",
            "repairOrderOpenDate": "2021-11-22",
            "deliveryDate": "2020-11-12",
            "primaryFailedPartName": "Unable to Determine Caus",
            "primaryFailedPartNumber": "86",
            "claimStatusCode": "40",
            "claimStatusCodeDescription": "Approved",
            "claimType": "01",
            "exchangeRate": "1.0",
            "previousCreditAmount": 0,
            "partCreditTotal": 2620.01,
            "partMarkupTotal": 524,
            "laborCreditTotal": 769.5,
            "netItemCreditTotal": 108.06,
            "netTotalCreditDollars": 4021.57,
            "requestedTotalDollars": 4025.04,
            "differenceTotalDollars": 3.47,
            "documentNumber": "9900195648",
            "claimLineDetailRecord": [
                "approvedQuantity": 3.8,
                "replacedPartNumber": "",
                "partName": "",
                "laborOperationCode": "00094000",
                "partLandedMarkup": 0,
                "netItemCode": "",
                "proRate": 100,
                "type": "Labor",
                "grossCredit": 513,
                "totalCredit": 513,
                "processCode": "",
                "processMessage": ""
                "approvedQuantity": 0.5,
                "partName": "",
                "laborOperationCode": "00094006",
                "netItemCode": "",
                "proRate": 100,
                "type": "Labor",
                "grossCredit": 67.5,
                "totalCredit": 67.5,
                "processCode": "",
                "partName": "",
                "laborOperationCode": "00096901",
                "netItemCode": "",
                "proRate": 100,
                "type": "Labor",
                "processCode": "",
                "partName": "",
                "laborOperationCode": "00096400",
                "netItemCode": "",
                "proRate": 100,
                "type": "Labor",
                "processCode": "",
                "approvedQuantity": 0.4,
                "partName": "",
                "laborOperationCode": "00094100",
                "netItemCode": "",
                "proRate": 100,
                "type": "Labor",
                "grossCredit": 54,
                "totalCredit": 54,
                "processCode": "",
                "approvedQuantity": 3,
                "partName": "",
                "laborOperationCode": "",
                "netItemCode": "Parts",
                "proRate": 100,
                "type": "Other",
                "grossCredit": 108.06,
                "totalCredit": 108.06,
                "processCode": "",
                "approvedQuantity": 0,
                "partName": "",
                "proRate": 100,
                "type": "Other",
                "grossCredit": 0,
                "totalCredit": 0,
                "processCode": "981",
                "processMessage": "Shop supplies not allowed"
                "approvedQuantity": 1,
                "replacedPartNumber": "29563096",
                "partName": "1000RM RETRAN ASSEMBLY",
                "partLandedMarkup": 524,
                "netItemCode": "",
                "proRate": 100,
                "type": "Part",
                "grossCredit": 3144.01,
                "totalCredit": 3144.01,
                "processCode": "",
        "repairingOutletBusinessPartnerCode": "0322400600",
        "repairingOutletName": "Faulkner GMC",
        "repairingOutletAddressline1": "705 Auto Park Boulevard",
        "repairingOutletCity": "Chester",
        "repairingOutletCountry": "United States",
        "repairingOutletPostalcode": "19382",
        "kilometerIndicator": "",
        "currentLaborRate": "",
        "currentLaborRateEffectiveDate": "",
        "currentTravelDistanceReimbursementRate": "",
        "currentTravelDistanceReimbursementRateEffectiveDate": "",
        "currentLandedCostMarkup": "",
        "currentLandedCostMarkupEffectiveDate": "",
        "repairingOutletBusinessPartnerCode": "0322400602",
        "repairingOutletName": "Mohawk Valley Freightliner",
        "repairingOutletAddressline1": "703 Oriskany Boulevard",
        "repairingOutletCity": "Yorkville",
        "repairingOutletState": "NY",
        "repairingOutletPostalcode": "13495-0201",
        "repairingOutletBusinessPartnerCode": "0322400604",
        "repairingOutletName": "Bentley Truck Services  Inc.",
        "repairingOutletAddressline1": "7777 Essington Avenue",
        "repairingOutletPostalcode": "19153",
                         Additional Message Information
 Message ID . . . . . . :   RNX0356       Severity . . . . . . . :   50
 Message type . . . . . :   Escape
 Date sent  . . . . . . :   03/10/22      Time sent  . . . . . . :   12:50:10
 Message . . . . :   The document for the DATA-INTO operation does not match
   the RPG variable; reason code 5.
 Cause . . . . . :   While parsing a document for the DATA-INTO operation, the
   parser found that the document does not correspond to RPG variable "PARM"
   and the options do not allow for this. The reason code is 5. The exact
   subfield for which the error was detected is "PARM(1)". The options are
   "doc=file case=convert countprefix=num_ allowextra=yes
   path=jsonDoc/CREDITADVICEHEADER/REPAIRINGOUTLETRECORD". The document name is
   /Allison/4Ward/Credit Advice Response Example.json; *N indicates that the
   document is not an external file. The parser is 'YAJLINTO'. *N indicates
   that the parser is a procedure pointer.
The top portion of the handler procedure:
dcl-proc processRepairOutletRecord;
dcl-pi *n  int(10);
   count  int(10);
   item   likeDS(REPAIRINGOUTLETRECORD_T)  Dim(1)  Const;
   items  int(10)  Value;
Like I said it works wonderfully until it reaches a certain point in the JSON (which is attached).
Any suggestions? If you need any more information, please let me know.
Thanks in advance!
Re: DATA-INTO Failing (Different Issue)
Eric,
Are you certain that you posted the correct error message? I tried your example, but I get a different one:
 Date sent  . . . . . . :   03/10/22      Time sent  . . . . . . :   15:30:43
   the RPG variable; reason code 8.
   and the options do not allow for this. The reason code is 8. The exact
   subfield for which the error was detected is "PARM(1).currentlaborrate". The
   options are "doc=file case=convert countprefix=num_ allowextra=yes
   test/Credit Advice Response Example.json; *N indicates that the document is
   not an external file. The parser is 'YAJLINTO'. *N indicates that the parser
 Recovery  . . . :   Contact the person responsible for program maintenance to
        More...
 Press Enter to continue.
 F3=Exit   F6=Print   F9=Display message details
 F10=Display messages in job log   F12=Cancel   F21=Select assistance level
   8. The document contains data that cannot be successfully assigned to the
     RPG variable. The RPG status code associated with the failure is 105.
Notice that it says RPG status code 105. So I typed the following command to find out what status code 105 means:
dspmsgd rnx0105 msgf(qrnxmsg)
A character representation of a numeric value is in error.
Looking at your JSON document you have this:
And in RPG the corresponding field is:
Firstly, the fact that this shows quote marks means that this is NOT intended to be a numeric field. But, you've defined it as packed, which means that any time they send character data that isn't a valid number, you'll get this error.
Second, there's a somewhat new (PTF was available in Fall 2020) feature in RPG called EXPROPTS(*ALWBLANKNUM) that will allow it to interpret blank values as zero. After I added that to my CTL-OPT, I was able to run the program without errors. For more info on EXPROPTS(*ALWBLANKNUM) see here: https://www.ibm.com/support/pages/node/6342819
With that, no errors -- works perfectly.
emhill
Post by emhill »
Hey Scott,
I think you told me about the EXPROPTS(*ALWBLANKNUM) before and I do have it in my CTL-OPT specs.
I'm getting the reason code of 5.
I'm going to change that currentLaborRate to character and see if that makes a difference. This company has been notorious for sending me examples of the JSON being sent and then just turn around and make wholesale changes without notification.
I'll play a little more and let you know what happens.
Thanks for the prompt reply.
Changing it to character would make sense if you were getting reason code 8 like I was.
Reason code 5 means that your variable name doesn't match the JSON field name. But, I ran your JSON example with your DS,and didn't have that problem. Any idea why mine wouldn't have the same problem?
Also -- and this is probably unrelated to the error -- in the processRepairOutletRecord procedure you have parameter 'items' defined as int(10), but the docs say it should be uns(10). I suspect it'd work fine as long as there are less than 2 billion items in the array (which should never happen) but you might want to change it to uns(10), anyway... just for the sake of "correctness"
emhill
Post by emhill »
Wow... I don't know. I'll attach my complete program and maybe there is something else going on there that you see. I'm writing to a flat file called ATDRCVWA that is 350 characters long.
This is a first draft so don't laugh too hard! :-)
ATD140.zip
(14.45 KiB) Downloaded 2606 times
Eric,
  1. You didn't send your program, you sent a printout created by SEU. This includes extra columns before/after the code as well as heading information, etc, because its designed to be sent to a printer. I can certainly strip all of this off -- but, why not send the source itself rather than a printout of the source, so I don't have to do extra work?
  2. The code calls a program called ATD148, which i don't have.
  3. The code uses the external definitions of a file called ATD140FIL which I don't have.
  4. It does SQL statements against files called WAHDR, WAITM, WALAB, WANET, and ICMST which I don't have.
Frankly, I've blown an hour on this and I haven't even gotten as far as trying to compile it.
So that I don't have to waste any more time, can you please create a copy of the program that reproduces the problem without these extra dependencies? It doesn't have to do anything else useful besides illustrate the problem. Make sure you test it before sending it to verify that it compiles, runs, and reproduces the problem.
I'm glad to help, but I don't want to get into the business of spending hours rewriting your code.
emhill
Post by emhill »
I"m sorry about that. I'll try to get you something better to work with.
emhill
Post by emhill »
I found it. I was performing this statement in my handler procedure:
%subst(rec:203:1) = %subst(item(1).kilometerIndicator:1:1);
That was where it was dying. The JSON for that element looked like this:
It was trying to substring a null(?). I just wrapped it up in a MONITOR to clear the resulting field when an error occurs. Now it is humming along.
Sorry I wasted your time with this. I do appreciate you taking a peek...
