Return multiple records from an RPG to a REST consumer
karldv22
Post by karldv22 »
Hello everyone,
The first thing is to introduce myself, my name is Carlos, an RPG developer for many years from Barcelone, Spain.
I've been following Scott for a long time although I don't usually use these forums but today I'm launching my first post here.
THEME
Following Scott's information about publishing RPG programs for SOAP or REST consumption
1. I have set up an IWS server on the I-Series and have developed a small test program
2. Consumers (SOAPUI) work perfectly with a GET operation and achieving a single record.
THE CHALLENGE
I don't quite understand how to return a group of records through the *ENTRY PARM
I need to return a JSON (which is already transformed by IWS) but with multiple records.
I'm not able to do it.
Here, attached code of the RPG service and SoapUI Results as a file
       //‚WSCUSTOMER
       //‚Webservice en RPG para exposición y uso
       //‚Carlos Del Valle
       //‚16/03/2022
       ctl-opt OPTION(*NODEBUGIO:*SRCSTMT) DFTACTGRP(*NO) THREAD(*SERIALIZE)
               ACTGRP('CDVREST') PGMINFO(*PCML: *MODULE);
       ctl-opt decedit('0,');
       //‚Database definition
       dcl-f COCLIN disk keyed usage(*INPUT) usropn ExtFile(file_coclin)
             prefix('CUST.');
       //‚General Definitions
       dcl-ds pgm_stat psds;
         sdsPgmID   char(10) pos(1);
         sdsWrkstn  char(10) pos(244);
         sdsJobUser char(10) pos(254);
         sdsCurUser char(10) pos(358);
         UsrId      char(10) pos(358);
         sdsJobnbr  char(6)  pos(264);
         sdsJobDate char(6) pos(270);
         sdsMsg     char(7)  pos(40);
         sdsMsgd    char(80) pos(91);
         sdsDate    char(8) pos(191);
       dcl-ds err qualified;
       bytesProv int(10) inz(0);
       bytesAvail int(10) inz(0);
       dcl-s MsgDta varchar(1000);
       dcl-s MsgKey char(4);
       dcl-s file_coclin char(21) inz('/COCLIN');
       dcl-s zxcias packed(3:0);
       dcl-s zxlist packed(1:0);
       //‚Back Error control
       dcl-pr QMHSNDPM ExtPgm;
         MessageID char(7) Const;
         QualMsgF char(20) Const;
         MsgData char(32767) Const options(*varsize);
         MsgDtaLen int(10) Const;
         MsgType char(10) Const;
         CallStkEnt char(10) Const;
         CallStkCnt int(10) Const;
         MessageKey char(4);
         ErrorCode char(32767) options(*varsize);
       end-pr;
       //‚Customer Record Estructure
         dcl-ds CUST ext qualified extname('COCLIN') end-ds;
       //‚*Entry Params
       dcl-pi *n;
         @ptran  char(25);                       // IN   Transacción
         @pcias  char(3);                        // IN   Compañía
         @pcust  like(Cust.s0cust);              // IN   Código Cliente (Not mandatory)
         @pCunm  like(Cust.s0des1);              // OUT  Nombre de Cliente
         @pVrno  like(Cust.s0nifi);              // OUT  Id Fiscal
         @pChai  like(Cust.s0grp2);              // OUT  Cadena Comercial
         @pPais  like(Cust.s0pais);              // OUT  Código de País
         @pZopa  like(Cust.s0zopa);              // OUT  Zona Comercial
         @pSupa  like(Cust.s0supa);              // OUT  SubZona Comercial
         @presu  char(3);                        // OUT  Resultado OK/NOK
         @pidms  char(10);                       // OUT  ID Mensaje
         @ptxms  char(150);                      // OUT  Texto Mensaje
       //‚Program Structure
        file_coclin = 'PURLIBF' + @pcias + file_coclin;
        open(e) coclin;
           zxcias=%dec(@pcias:3:0);
           select;
             when @ptran='GetCust';
             exsr cs_GetCust;
             when @ptran='ListCust';
             exsr cs_ListCust;
           endsl;
       //‚End
        close(e) *all;
        *inLR = *on;
        begsr cs_GetCust;
           chain (zxcias:@pcust) coclin;
           if %found(coclin);
             exsr cs_MoveData;
             @presu='OK';
             @pidms=*Blanks;
             @ptxms=*blanks;
             @presu='NOK';
             @pidms='CPF9897';
             @ptxms='Customer not found.';
             //msgdta='Customer not found.';
             //QMHSNDPM( 'CPF9897' : 'QCPFMSG   *LIBL' : msgdta : %len(msgdta)
             //: '*ESCAPE' : '*PGMBDY' : 1 : MsgKey : err );
        endsr;
        begsr cs_ListCust;
          zxlist=0;
          setll (zxcias) coclin;
          reade (zxcias) coclin;
          dow not %eof(coclin);
             zxlist=1;
             exsr cs_MoveData;
             @presu='OK';
             @pidms=*Blanks;
             @ptxms=*blanks;
          enddo;
          if zxlist=0;
            @presu='NOK';
            @pidms='CPF9897';
        endsr;
        begsr cs_MoveData;
          @pcust=Cust.s0cust;
          @pCunm=Cust.s0des1;
          @pVrno=Cust.s0nifi;
          @pChai=Cust.s0grp2;
          @pPais=Cust.s0pais;
          @pZopa=Cust.s0zopa;
          @pSupa=Cust.s0supa;
        endsr;
Re: Return multiple records from an RPG to a REST consumer
This is the program PI for a simple test program I use in IWS presentations. (I used code tags in square brackets to format this - your code as you probably noticed is pretty much unreadable)
If you use the first approach I have shown here then you need to DE-SELECT the "Detect Length Fields" on the wizard's parameter page. When you do so the wizard display changes and you then have the opportunity to select the productList_count field as the controller for the number of output records.
dcl-pi RestSrv4 ExtPgm;
   requestedCat        Like(catcod);
   result              char(20);
   productList_count   int(5);
   productList         LikeDS(product)  Dim(20);
There is an alternative approach that does use the "Detect" setting and in that case the PI looks like this.
dcl-pi RestSrv5 ExtPgm;
  result              char(20);
  productList         LikeDS(productList_T);
Dcl-ds  product ExtName('PRODUCT')  End-ds;
Dcl-ds  productList_T  Qualified Template;
  products_LENGTH  int(5);
  products         LikeDS(product)  Dim(20);
End-Ds;
Note that _LENGTH is the compulsory spelling and (for some weird reason) has to be in upper case. In my first example the name can be anything you choose. But if you choose to let IWS detect the length then it determines the spelling.
Using the first method the count is included in the generated JSON data. Using the second method no count is included.
If you want I can share with you a video of a presentation I did which uses these examples, but I don't want to publicly share this version so email me privately if you want to see it.
I hope this helps.
karldv22
Post by karldv22 »
Muchas Gracias !!!!!
It has run perfectly with the first approach.
Just a small problem to comment, I can't use Variable Dimension Array (RPG Limitation) and the JSON result is left with empty records once the content is processed.
I will study an alternative.
Saludos
Just use a regularly defined RPG array and either of the answers I gave you when applied correctly will result in NO empty entries being output. Just make sure to set the value in the count field to the number of _active_ elements.
Look at the output of this: http://sidconf.idevcloud.com:10025/web/ ... ESTSRV5/02 the program allows for Dim(99) but only 5 were used. Change the number part to 01 and you'll see the change.
You just need to do what I showed you and the problem disappears.
P.S. You can use a varying length array as a parameter but you must set its length appropriately and define the PI/PR as the max. I describe how this works here: https://www.itjungle.com/2020/10/12/gur ... -and-more/
karldv22
Post by karldv22 »
Thanks a lot jonboy49,
I'll follow docs you linked me, and I'll do R+D, I'm working with this "in bursts" but When I'll have the final test working fine, i'll shared code and my humble conclusion in order to help everybody interested in this.
karldv22
Post by karldv22 »
Hi jonboy49,
I've been trying to send you a private e-mail such you offered me a video about this tophic, but i could not find your e-mail in your profile.
I would like go deep with this but really now i'm stuck and i've been trying differents RPG code but i've not still got good result.
Any help will be appreciated
Carlos
Sorry for the delay - I missed the posting of your request.
The video can be found here:
https://us02web.zoom.us/rec/play/3penvq ... 13yEo4xHTI
Let me know if you have any questions. Business email is jon dot paris at partner400 dot com. But if the question is of general interest please post it here.
karldv22
Post by karldv22 »
Thanks a lot jonboy49 !!!
With this amazing video I could to code my RPG program and following the API deployment details, I could to run it perfectly and cutting the empty JSON.
I hope this topic will help people that likes to implement this IWS
kind regards
