Timeout Using http_stmf
emhill
Post by emhill »
I am using the following to connect and post to a remote site. It then sends data back in JSON format:
http_stmf( 'POST'
         : claimurl
         : resultpath
         : jsonpath
         : 'application/json');
I am getting a timeout error in the httpapi_debug.txt. If I run this using PostMan it works but takes about two minutes to connect and retrieve the data. Is there a default timeout on the http_stmf? This has been working for a while now but today decides to stop with the timeout errors.
I'm going to get with the receiving site to see if anything is amiss there as well.
Thanks!!!
Re: Timeout Using http_stmf
HTTPAPI ships with a default timeout of 60 seconds.
You can override it like this:
http_setOption('timeout': '300');   // timeout = 5 minutes
emhill
Post by emhill »
Perfect!!!! Thanks Scott....
