Trouble with post request
lgiammattei
Post by lgiammattei »
Hi everybody, hope someone could help me understando qhat i am doing wrong.
I am using httpapi to perform a POST request, the expected result is a JSON file that i want to save in the IFS for later use. The JSON contains a JWT token but that is not important now.
I tried the request using SOAP UI and it works smooth, trying to replicate the request via httpapi a get an error.
Here is the raw request as it appears on the SOAPUI client window
POST https://xxxxxxx.xxxx.xx/identityserver/ ... &scope=ccc HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: application/x-www-form-urlencoded
Content-Length: 82
Host: xxxxxxx.xxxx.xx
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
here is the raw response from SOAP UI client
Cache-Control: no-store, no-cache, max-age=0
Pragma: no-cache
Content-Type: application/json; charset=UTF-8
Server: Microsoft-IIS/8.5
X-Powered-By: ARR/3.0
Date: Tue, 07 Jun 2022 12:31:35 GMT
Content-Length: 803
{"access_token":"eyJhbGciOiJSUzI1NiIsImtpZCI6IjM5ODUzQzhBOEI3RjU2QkJBQ0IxMzg2QjBDOTdBNkJFNzE0OENFRkUiLCJ0eXAiOiJKV1QiLCJ4NXQiOiJPWVU4aW90X1ZydXNzVGhyREplbXZuRkl6djQifQ.eyJuYmYiOjE2NTQ2MDUwOTgsImV4cCI6MTY1NDYwODY5OCwiaXNzIjoiaHR0cHM6Ly9zZXJ2aXppLmZpZ2MuaXQvaWRlbnRpdHlzZXJ2ZXIiLCJhdWQiOlsiaHR0cHM6Ly9zZXJ2aXppLmZpZ2MuaXQvaWRlbnRpdHlzZXJ2ZXIvcmVzb3VyY2VzIiwiTE5EIl0sImNsaWVudF9pZCI6IkxuZENsaWVudCIsInNjb3BlIjpbIkxORCJdfQ.YyNbsNrBsnmTJABN2YXzwzjFEm3o6zXcLe_X6Ha9H95WkSGkOJNIt0Wj0G9WfNJtKJXjb24ZXW_Ml2-2yy8sYS3zeDfOyjJHFvSZOSHr2sy2ePvBd68oqG62ELAnYBW90XAk69sBuQsUoJQv6V_TzRSApggy5TDV-NAAt4FuNmqriTv6ckFhbxXzlDnHhakphmBf6UGlVOQF0QB5-pMHJ3buUVlIPhk9rHg583d2EAypmZfyE5LuNIGPDhe8X8zAELSYFEWEALYyWOJiFFvOHWs-BIJFKPl9F18QN3ItJAA1L1SJeq2ytHI2lIKgKXol04O-m7ayL7pOuI_aEavHnQ","expires_in":3600,"token_type":"Bearer"}
here is my rpg snippet code
       http_debug(*ON: debugLog + 'httpapi_testLog.log');
       http_setCCSIDs( 1208: 0 );
       URLTOJWT='https://xxxxxxx.xxxx.xx/identityserver/connect/token';
       postData='?client_id=' + %Trim(TClientId) +
                '&client_secret=' + %Trim(TClientSecret) +
                '&grant_type=' + %Trim(TGrantType) +
                '&scope=' + %Trim(TScope);
       IFS=debugLog + 'httpapi_testJSON.json';
       rc = http_post(URLTOJWT
                      : %addr(postData) + 2
                      : %len(postData)
                      : IFS
                      : HTTP_TIMEOUT
                      : HTTP_USERAGENT
                      : 'application/x-www-form-urlencoded' );
Following is a snipet from the testlog file
POST /identityserver/connect/token HTTP/1.1
User-Agent: http-api/1.45
Content-Length: 83
?client_id=aaaaaaa&client_secret=bbbbbb&grant_type=client_credentials&scope=ccc
HTTP/1.1 400 Bad Request
Pragma: no-cache
Date: Tue, 07 Jun 2022 13:07:15 GMT
Content-Length: 26
SetError() £13: HTTP/1.1 400 Bad Request
recvresp(): end with 400
recvdoc parms: identity 26
SetError() £0:
recvdoc(): Receiving 26 bytes.
{"error":"invalid_client"}
and in the json file i find only {"error":"invalid_client"}
Can any kind soul out there point me to an error or mistake i am doing?
TIA
lgiammattei
Re: Trouble with post request
i forgot to write that i am using
OS/400 Ver V7R3M0
Are you certain that you should be sending your data in the URL? That sort of defeats the point of using POST, doesn't it?
Also, you don't appear to be calling the url-encoding routines. Is the data already encoded?
lgiammattei
Scott thanks for your attention,
i know, but in SOAP UI it works
that is something i forgot, now i am out of office but tomorrow morning will be my first try.
Thx again
lgiammattei
Solved. I had made a mistake in the postData string variable for the request
deleting the question mark at the begin of the string (i copied and pasted the string from the SOAP Ui screen) made everything works fine.
