New version but old error not corrected? and new function not implemented.
Scott Klement's tool for processing CSV files in an RPG program. http://www.scottklement.com/csv/
peder udesen
Post by peder udesen »
Hi Scott
I have found out you have made a new version of CSVR4 that can handle UTF. Excellent.
But I have 2 questions.
1)
But when I'm looking in the source it looks like you haven't corrected an error that was reported in 2010:
Employee_ID,StateCode,FilingStatus
51,,
A1,TX,
B3,OK,S
The first 2 records will not return the correct number of fields, while the third one will.
Am I right?
2)
In 2009 you suggested a function to load a record from user-supplied string called CSV_loadbuffer().
The code was the following. But it seems you haven't implemented it in the new version.
      * CSV_loadrec(): Load a record from a delimited file into memory
      *     peHandle = (i/o) handle to file returned by CSV_open()
      * Returns *ON if successful, *OFF upon failure or EOF
     P CSV_loadrec     B                   export
     D CSV_loadrec     PI             1N
     D   peHandle                          like(CSV_HANDLE) value
     D CSV             DS                  likeds(CSVFILE_t)
     D                                     based(peHandle)
     D p_buf           s               *
     D len             s             10I 0
      /free
         %len(CSV.buf) = %size(CSV.buf) - VARPREF;
                 %len(CSV.buf) = len;
        if (%subst(CSV.buf : len : 1) = LINEFEED );
           len = len - 1;
        if (%subst(CSV.buf : len : 1) = CARRTN );
           len = len - 1;
        csv_rewindrec(peHandle);
        return *ON;
     /end-free
    P                 E
Regards
Peder
PS: I have pdf-files with the old entries from Systemi Networks Forum ( long gone ) but I'm not allowed to attach them.
Re: New version but old error not corrected? and new function not implemented.
I'm not familiar with CSV_loadbuffer, but there is an CSV_openbuf in the current release. Will that help?
peder udesen
Have you checked if the old bug has been fixed or still exists?
Regards
Peder
peder udesen
Please forgive me. I put the wrong source in the above example for CSV_loadbuffer()
Here it is:
 * CSV_loadbuffer(): Load record from user-supplied string.
 *        peBuf = (input) data to load into record buffer
P CSV_loadbuffer  B                   export
D CSV_loadbuffer  PI             1N
D   peBuf                    65502a   varying const options(*varsize)
D                                     based(peHandle)
 /free
    CSV.buf = peBuf;
    return *ON;
 /end-free
P
peder udesen
Do any of you know if the old bug has been fixed in the new version?
CSV_loadbuffer was from a forum discussion, and has never officially been a part of the CSVR4 tool. Is this something you think should be added? If so, can you explain why you would use this instead of CSV_openBuf?
I don't agree with the other proposed change ("bug fix").
peder udesen
Thank you for your response. I didn't want to offend you.
