DATA-INTO and ALWBLANKNUM
emhill
Post by emhill »
I have a process that has been working for a while but the provider has suddenly decided (in some instances) to show resulting numeric fields that are zero as "". For example:
"netTotalCreditDollars": ""
When before it was "netTotalCreditDollars": 0
They have done this in the past and corrected the issue but I have this control spec in my program:
ctl-opt dftactgrp(*no) EXPROPTS(*ALWBLANKNUM);
I thought that would have handled it. Is that not the case? Here are my control specs:
ctl-opt bnddir('QC2LE':'YAJL');
And here is my data-structure:
dcl-ds CLAIMPROCESSEDRECORD dim(100);
  TRACKINGNUMBER varchar(10) inz('');
  REPAIRORDERNUMBER varchar(8) inz('');
  PRODUCTSERIALNUMBER varchar(20) inz('');
  CLAIMNUMBER varchar(20) inz('');
  MODELNUMBER varchar(15) inz('');
  REPAIRORDEROPENDATE varchar(10) inz('');
  DELIVERYDATE varchar(10) inz('');
  PRIMARYFAILEDPARTNAME varchar(25) inz('');
  PRIMARYFAILEDPARTNUMBER varchar(20) inz('');
  CLAIMSTATUSCODE varchar(3) inz('');
  CLAIMSTATUSCODEDESCRIPTION varchar(20) inz('');
  CLAIMTYPE varchar(2) inz('');
  EXCHANGERATE varchar(10) inz('');
  PREVIOUSCREDITAMOUNT packed(10:2) inz(0);
  PARTCREDITTOTAL packed(9:2) inz(0);
  PARTMARKUPTOTAL packed(9:2) inz(0);
  LABORCREDITTOTAL packed(10:2) inz(0);
  NETITEMCREDITTOTAL packed(9:2) inz(0);
  NETTOTALCREDITDOLLARS packed(9: 2) inz(0);
  REQUESTEDTOTALDOLLARS packed(9: 2) inz(0);
  DIFFERENCETOTALDOLLARS packed(9: 2) inz(0);
  DOCUMENTNUMBER varchar(20) inz('');
This is the JSON that is getting the error:
            "trackingNumber": "M023444489",
            "repairOrderNumber": "R336205A",
            "productSerialNumber": "6511747863",
            "claimNumber": "AT0520867",
            "modelNumber": "3414RHS",
            "repairOrderOpenDate": "2022-07-26",
            "deliveryDate": "2021-03-04",
            "primaryFailedPartName": "ECU Recalibration",
            "primaryFailedPartNumber": "400",
            "claimStatusCode": "50",
            "claimStatusCodeDescription": "Denied",
            "claimType": "01",
            "exchangeRate": "1.0",
            "previousCreditAmount": 0,
            "partCreditTotal": 0,
            "partMarkupTotal": 0,
            "laborCreditTotal": 313.75,
            "netItemCreditTotal": 36,
            "netTotalCreditDollars": "",
            "requestedTotalDollars": 450.15,
            "differenceTotalDollars": "",
            "documentNumber": "",
If they have a value they are represented correctly:
            "trackingNumber": "M023445044",
            "repairOrderNumber": "345661",
            "productSerialNumber": "6610550609",
            "claimNumber": "AT0526774",
            "modelNumber": "4500RDS_P",
            "repairOrderOpenDate": "2022-09-09",
            "deliveryDate": "2019-06-25",
            "primaryFailedPartName": "BODY-VALVE, MAIN, 6SPD",
            "primaryFailedPartNumber": "29557154",
            "claimStatusCode": "40",
            "claimStatusCodeDescription": "Approved",
            "claimType": "04",
            "partCreditTotal": 260.75,
            "partMarkupTotal": 52.14,
            "laborCreditTotal": 715.35,
            "netItemCreditTotal": 46.24,
            "netTotalCreditDollars": 1074.48,
            "requestedTotalDollars": 1074.49,
            "differenceTotalDollars": 0.01,
            "documentNumber": "9900197704",
Am I missing something on the *ALWBLANKNUM value or somewhere else?
Thanks!!!!
Re: DATA-INTO and ALWBLANKNUM
Like you I would expect that to work. You do have the runtime PTF for this installed right?
One solution (if this is an urgent production issue) is to change the definition of the field(s) in question to alpha and then manually convert them to numeric where you could use MONITOR to trap conversion errors. This was the approach IBM used to recommend for XML-INTO and the situation is basically the same.
emhill
Post by emhill »
Hey Jon,
I've got an email in to the provider to see why that got changed. I think I will have to do as you suggest and work around it. It may get fixed but it also might crop up again.
Thanks for the prompt response!!!!!
By the way (just for grins) do you know off hand what the runtime PTF you mentioned?
No and I can’t look it up right now but the RPG Cafe has it listed
You can find the PTFs here -- though, I don't see why you'd want to install the PTF numbers from 2020 -- just install the current ones then you'll have all of the new features and fixes.
https://www.ibm.com/support/pages/node/6342819
