We're on OS v7r4
One of my programs is failing with the following error:
CommTCP_read: Socket has been shut down.
URL that I'm attempting:
http://192.168.999.998/SendEmail/SendEm ... &subj=Test
If I enter the url from a browser window, it works. When I call the url from the program on the IBM, it fails with the error msg.
Here's a code snip:
URL = 'http://' + %trim(server) + %trim(ASP) +
'?' + %trim(data);
rc = http_url_get_raw(%trim(URL): *loval: %paddr('INCOMING'):30);
Here's the debug log info:
OS/400 Ver V7R4M0
DNS resolver retry : 2
DNS default domain: domain_name
DNS server found: 192.168.999.999
http_persist_get(): entered
do_oper(GET): entered
GET /SendEmail/SendEmail.aspx?from=tom@myserver.com&to=tom@myserver.com&msg=Test&subj=Test
HTTP/1.1
Host: 192.168.999.998
User-Agent: http-api/1.45
SetError() #44: CommTCP_read: Socket has been shut down.
recvresp(): end with err
Error: CommTCP_read: Socket has been shut down.
Re: Error: CommTCP_read: Socket has been shut down.
I assume you changed the IP addresses in the log -- since they are nonsensical and invalid.
The error indicates an error reading from the network. Typically it means that the OS said there was data to read from the socket, but then when it requested the data, it got none.
This can happen with SSL sockets because some of the bytes from the network are used to handle the cryptography, so aren't actually data. Current versions of HTTPAPI understand this and will re-try.
But, this appears to be a TCP (non-SSL) socket from what you've posted. I've not heard of that happening... My guess is that there is some sort of network error, but I don't know what, specifically... never seen it before.
I did obfuscate the IP addresses, company policy.
So I'm thinking I'm not all the way current on httpapi - if I install the most-recent version, will I need to recompile my programs that are compiled with the httpapi headers?
No, you don't have to recompile your programs.
