Wrong response with HTTPAPI
g.scantee
Post by g.scantee »
Hi Everyone!
I'm looking for some help. I need to make an API call with a "GET" request.
RESPONSE = http_string('GET': url: request: 'application/json');
This API return me a PDF file in base64 format.
Everything works fine, but when I get the answer of the call, the response reverses the "//" to "\/"
For example:
The value it should have is this : RESPONSE = "TLs1x2//fvuUn2uWn7XH8vPr52CO579fP3//7//PL5x+f6+dfn//vndZv39c"
But it return me this: RESPONSE = "TLs1x2\/fvuUn2uWn7XH8vPr52CO579fP3\/7\/PL5x+f6+dfn\/vndZv39c"
As you can see the first "/" is reversed to "\"
How can i fix it?
Thanks in advance.
Re: Wrong response with HTTPAPI
I've never heard of HTTPAPI doing something like this before, and I can't think of any way it'd do that.
Can you tell me how to reproduce the problem?
g.scantee
Post by g.scantee »
Here is all the code.
       ctl-opt option(*srcstmt:*NODEBUGIO) dftactGrp(*no)
               bnddir('HTTPAPI':'YAJL') DecEdit('0.');
       /copy httpapi_h
       /copy yajl_h
       dcl-pr cmd extpgm('QCMDEXC');
         command varchar(200) const;
         length packed(15:5) const;
       END-PR;
       // Global variable
       //dcl-s respx    varchar(80);
       dcl-s urlx     varchar(80);
       dcl-s ID_x     PACKED(3:0);
       DCL-S pippo      varchar(120);
       DCL-S DataInizPgm  Packed(8:0);
       DCL-S OraInizPgm   Packed(6:0);
       Exsr SetUp;
       if not translate();
         Exsr $Exit;
       ENDIF;
       Exsr $Exit;
       // SetUp  subroutine
       Begsr SetUp;
         DataInizPgm = %Dec(%Date():*Iso);                      //Data inizio pgm
         OraInizPgm  = %Dec(%Time():*Iso);                      //Ora inizio pgm
       ENDSR;
       // Uscita dal programma
       BEGSR $Exit;
         *Inlr = *On;
         Return;
       EndSr;
       // Crea Json e invoca Web Service
       dcl-proc translate;
         DCL-PI *N IND;
         END-PI;
         dcl-s url      varchar(2000);
         dcl-s request  varchar(2000);
         dcl-s response varchar(1000000); //1mb
         dcl-s output   varchar(1000);
         dcl-s errMsg   varchar(500);
         dcl-s wait     char(1);
         dcl-s docNode  like(yajl_val);
         dcl-s node     like(yajl_val);
         dcl-s httpcode varchar(1024);
         http_xproc(HTTP_POINT_ADDL_HEADER: %paddr(add_accept_header));
         yajl_genOpen(*OFF);
         yajl_beginObj();                     // {
         yajl_addChar('id':'9999999');
         yajl_endObj();                       // }
         request = yajl_copyBufStr();
         yajl_genClose();
         http_setOption('local-ccsid': '0');
         url = 'https://Api-Key-example/api/';
           response = http_string('GET': url: request: 'application/json');
           httpcode = http_error();
         docNode = yajl_string_load_tree(response: errMsg);
         urlx  = url;
         RETURN *ON;
       end-Proc;
       // Set headers
       dcl-proc add_accept_header;
         dcl-pi *n;
           extraHeader varchar(1024);
         dcl-c CRLF x'0d25';
         extraHeader += 'API-Key: ' + %Trim(Api) + CRLF;
       end-proc ;
I don't have any of your valid item codes (or whatever they are) to test with and had to guess that you just added the value to the URL but ...
Using Insomnia to test the service I found that it can actually return \/ - so I'm guessing this is nothing to do with HTTPAPI and you may need to contact the vendor. Using the URL XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX the API returns:
	"status": "KO",
	"err": "API sconosciuta: getLdv\/123"
Since this is JSON and it uses the \ as an escape character - my guess is that this is normal behaviour.
Two suggestions:
1) Use a tool like Insomnia or SoapUI or ... to test the call. I think you'll find it sees the same data as HTTPAPI
2) It is not a good idea to publish your personal access code in a public forum. Assuming that that is what you have done. Certainly, when I used that code I no longer got authorization errors.
Yes, if indeed what you are seeing is JSON, the \ before the / is completely normal and expected. And it's not in any way related to HTTPAPI -- that's what the server is responding with, and it's doing that because it has to in order to follow JSON standards.
When you interpret that JSON with a tool that understands JSON (DATA-INTO, YAJL procedures, SQL, etc) those will be removed to make the code normal.
However, there was absolutely nothing in your original response that indicated JSON? What you had was this:
So please clarify... is the result a JSON document, or is it a string like the above?
g.scantee
Post by g.scantee »
Hi Scott and everyone ,
I noticed that the result is not a json document. Returns a string format.
To be clear, on POSTMAN when I make the request it automatically converts the result to a JSON, for "pretty view", but if I change the return type from "JSON" to "TEXT", the result is identical to that of the HTTPAPI, i.e a string.
Just to clarify, the risult is in JSON String:
{"ord_id":"xxxxxxx","ldv":"TLs1x2\/fvuUn2uWn7XH8vPr52CO579fP3\/7\/PL5x+f6+dfn\/vndZv39c
5Wf33\/++Kfy8+fPb\/vP\/\/gF\/rvy\/9O3ISvmyeTf3+zz559\/VdnE8h
7H5XSOKPsL5pY4e3xv53C0eXD33BJnj\/1xDkebB3fPLXH22KpzONo8uHtui
bPH2pzD0ebB3XNLnD0+3TkcbR7cPbfE2eP9OoejzYN7Defu0bhlOoejzYO75
5Y4Z0Q7NE5xp8s7Xd3homKYIW13BboL0HzfGHrsvvnmm++9+pYxtNh49X1X3"}
The response that i need, is this, in JSON type.
"ord_id":"xxxxxxx",
"ldv":"TLs1x2/fvuUn2uWn7XH8vPr52CO579fP3/7/PL5x+f6+dfn/vndZv39c
5Wf33/++Kfy8+fPb/vP//gF/rvy/9O3ISvmyeTf3+zz559/VdnE8h
7H5XSOKPsL5pY4e3xv53C0eXD33BJnj/1xDkebB3fPLXH22KpzONo8uHtui
without "\"
Is possible make it to return me a response in JSON format and not in JSON String?
If not, how can i convert the response that is in string format to the JSON format? Can you help us.
Thanks in advance.
I don't understand what you are saying.
First you say it's not a JSON document -- then you show me a JSON document.... Then you ask me how you can make it not be a JSON document.
to be absolutely clear: HTTPAPI merely downloads, byte-for-byte what the HTTP server sends. It does not change the format of the data in any way, except in some circumstances it will convert it to EBCDIC.
It never inserts \ characters or converts it from a string to a JSON document. That is simply what the server is sending you.
Just use a JSON tool to interpret it -- this isn't rocket science.
