Cant get HTTPAPI to work
dirthawger
Post by dirthawger »
Hey everyone,
I'm having an issue getting HTTPAPI to work on our system. I have everything installed and in LIBHTTP. However, I can't even access any of the code because I keep getting an RNF0273 error, "Compiler not able to open the /COPY or /INCLUDE file; directive ignored." Here is some of my code:
 ctl-opt option(*nodebugio) dftactgrp(*no) bnddir('LIBHTTP/HTTPAPI');
          dcl-f APITEST01D workstn indds(indicators);
          dcl-ds indicators len(99);
            EXIT ind pos(7);
          dcl-pr cmd extpgm('QCMDEXC');
            cmd char(200) const;
            len packed(15:5) const;
          end-pr;
          dcl-s url    varchar(100);
          dcl-s header varchar(100);
          /copy qrpglesrc,httpapi_h
Have we somehow installed it wrong or am I missing a setting? It will compile without /copy directive so I'm guessing the bnddir is correct. I'm a fairly new RPGLE programmer so if someone could help that'd be great.
dirthawger
Re: Cant get HTTPAPI to work
I apologize for not checking first, but I'm using miworkplace as my IDE, for some reason I can't compile it in the IDE but it compiles successfully on the green screen.
vhamberg
Post by vhamberg »
This sounds like a library list problem - you need to find how to set the library list in MIWorkplace for compilations. We don't use it here, so I don't know where to look.
Anyhow, welcome to the wonderful world of RPGLE!
Vern
dirthawger
Yea I got that part covered and it recognizes the library and I can see all the procedures in my spooled file but I still can't get a simple http_get program to compile. Says *RNF0637 30 1 An operand was expected but was not found; specification is
ignored.
ctl-opt option(*nodebugio) dftactgrp(*no) bnddir('HTTPAPI')
              actgrp('HTTPAPI');
            EXIT ind pos(7);
          end-pr;
          dcl-s URL    varchar(100) inz('http:///alpha.sportssouth.biz/+
                _roman/test_api.php?NUMBER_IN=12345');
          dcl-s rc int(10);
          dcl-s msg varchar(52);
          dcl-s status int(5);
          dow not EXIT;
            exfmt scrn1;
            callp http_debug(*on);
            rc = http_url_get(:URL:'/tmp/api_test.txt');
            if rc <> 1;
              callp http_crash;
            callp cmd('DSPF ''/tmp/api_test.txt''': 200);
            if EXIT = *on;
              leave;
          enddo;
I dunno, thinking of just trying to do it with the SQL HTTPGETCLOB, but HTTPAPI looked a lot easier
You have a spurious colon in front of URL - it should be:
rc = http_url_get(URL:'/tmp/api_test.txt');
I just noticed that you also have an extra / in the URL you are calling. Which by the way won't work for me either
dirthawger
Much appreciated for the responses, but I finally figured out the problem. I checked the version of HTTPAPI on our system and it was from 2014. Installed new HTTPAPI and so far everything works as it should. Spent about 8 hours on this today only to try this within the last 45 mins.
