yajl_get_string() issue
THIYAGARAJAN
Post by THIYAGARAJAN »
Hi All,
I am parsing the Json date into tree using yajl_stmf_load_tree and I was able to get the key value but when I try to get value using yajl_get_string(val) to get the value of the node, I am getting an error saying that
Message . . . . : The call to YAJL_GET_S ended in error (C G D F).
Message . . . . : Length of varying length variable is out of range.
Anyone faced this issue before, can you give some suggestions?
Re: yajl_get_string() issue
Some of your code would help. For example of the call sequence and the definitions of the relevant fields. An extract of the relevant portion of the json would;d be useful too.
