Issue with yajil_buf_load_tree From a VARCHAR string
abermudez
Post by abermudez »
I am currently using YAJL to deconstruct a JSON string.
I am using: docNode = yajl_buf_load_tree(%addr(GetUri_Out) : %len(%trim(GetUri_Out)) : ErrMsg );
I am using GETURI to get mu HTTP Response and the GetUri_Out is a varchar(1048576) value holding the web response. When using the code above I get “parse error: premature EOF”. If I move the GetUri_Out to a char(1048576) value it works with no errors.
For performance purposes I do not wish to move a varchar to a char in order to process it. Is there a way to load a varchar value using yajl_buf_load_tree or is there another method I should be using?
Angel Bermudez
abermudez
Re: Issue with yajil_buf_load_tree From a VARCHAR string
Post by abermudez »
OK I resolved the varchar() issue .
I used docNode = yajl_buf_load_tree(%addr(GetUri_Out:*data) : %len(GetUri_Out) : ErrMsg );
and I get no more errors.
