XML-INTO error RNX0305, reason code 1
lburkett
Post by lburkett »
The XML-INTO instruction in my program below gets error RNX0305, "The specified path to the XML element was not found in the XML document." The value of RESPONSE is
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/e'
nvelope/"><soap:Body><ns2:cstitmwebResponse xmlns:ns2="http:'
//cstitmweb.wsbeans.iseries/xsd"><return><COMPANY>1</COMPANY'
><CONTRACT> </CONTRACT><CUSTCODE> </CUSTCODE><CUSTOMER>9'
876543210</CUSTOMER><EXPIREDATE>6212022</EXPIREDATE><FUNCTIO'
N>E</FUNCTION><ITEM>921530D </ITEM><ITEMC'
ODE> </ITEMCODE><PRICECODE>D</PRICECODE><PRICEDISCCODE>0</PR'
ICEDISCCODE><PRICELIST>0</PRICELIST><PRICEPCT>1.00000</PRICE'
PCT><QTYLIMIT>0.000</QTYLIMIT><STARTDATE>6192022</STARTDATE>'
<TYPE>CI</TYPE></return></ns2:cstitmwebResponse></soap:Body>'
</soap:Envelope> '
H DFTACTGRP(*NO) BNDDIR('HTTPAPI')
 /copy qrpglesrc,httpapi_h
D return          ds
D  COMPANY                       2  0
D  CONTRACT                      5
D  CUSTCODE                      1
D  CUSTOMER                     10  0
D  EXPIREDATE                    8  0
D  FUNCTION                      1
D  ITEM                         27
D  ITEMCODE                      1
D  PRICECODE                     1
D  PRICEDISCCODE                 1
D  PRICELIST                     1
D  PRICEPCT                      4  2
D  QTYLIMIT                      1  0
D  STARTDATE                     8  0
D  TYPE                          2
D response        s           1000    varying
D soap            s           1000    varying
D url             s            100    varying
  http_debug(*ON);
  url = 'http://192.168.1.200:10021/web/services/+
          CSTITMWEBService/CSTITMWEB';
  http_setOption('SoapAction': '""');
  soap = '<soapenv:Envelope +
    xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" +
     xmlns:xsd="http://cstitmweb.wsbeans.iseries/xsd"> +
       <soapenv:Header/> +
       <soapenv:Body> +
        <xsd:cstitmweb> +
           <arg0> +
              <_COMPANY>01</_COMPANY> +
              <_CONTRACT> </_CONTRACT>+
              <_CUSTCODE> </_CUSTCODE>+
              <_CUSTOMER>9876543210</_CUSTOMER> +
              <_EXPIREDATE>06212022</_EXPIREDATE> +
              <_FUNCTION></_FUNCTION> +
              <_ITEM>921530D</_ITEM> +
              <_ITEMCODE> </_ITEMCODE> +
              <_PRICECODE>D</_PRICECODE> +
              <_PRICEDISCCODE>0</_PRICEDISCCODE> +
              <_PRICELIST>0</_PRICELIST> +
              <_PRICEPCT>1.00</_PRICEPCT> +
              <_QTYLIMIT>0</_QTYLIMIT> +
              <_STARTDATE>06192022</_STARTDATE> +
              <_TYPE>CI</_TYPE> +
           </arg0> +
        </xsd:cstitmweb> +
     </soapenv:Body> +
  </soapenv:Envolope>';
  response = http_string( 'POST': URL: SOAP: 'text/xml');
  response =  %scanrpl('<_' : '<' : response);
  response =  %scanrpl('</_' : '</' : response);
  xml-into return %xml(response: 'case=any ns=remove');
  *inLR = *on;
Re: XML-INTO error RNX0305, reason code 1
Well as the error message says the path is incorrect - in fact you haven't specified a path at all.
Your code would work if your XML looked like this:
<return>
    <COMPANY>1</COMPANY>
    <CONTRACT></CONTRACT>
    <CUSTCODE></CUSTCODE>
    <CUSTOMER>9876543210</CUSTOMER>
But it has (namespaces removed as per your code)
<Envelope>
    <Body>
        <cstitmwebResponse >
            <return>
RPG can't just "hunt" for where <return> starts because there could be multiple <return> elements in different parts of the structure. So you have to tell ii where to start looking via a path= option on the XML-INTO. So in your case, you need to add something like path=Envelope/Body/cstitmwebResponse/return alongside your case=any etc..
lburkett
Post by lburkett »
That fixed it.
Is there a situation when the "path=" option is not required?
When you want to process the entire document rather than just a portion of it, path= isn't (or shouldn't be) required.
In your case you want to skip past the Envelope, Body, cstitmwebResponse and return elements, though... so you need it to tell XML-INTO what to skip
lburkett
Post by lburkett »
Thank you.
