My goal is to connect IBM i to Google Uploads Server (partnerupload.google.com). I am trying to do this using Expect tool. The Expect is installed on my IBM i machine. I wrote a program to use EXPECT tool. I get following error on the 'spawn' command.
Tcl_WaitForEvent: unable to start notifier thread
qsh: 001-0078 Process ended by signal 5.
I am not sure why I get this error. Is there anything related to my profile? What is causing this problem?
sFTP using Expect tool
Re: sFTP using Expect tool
Perhaps you are running in an environment that isn't enabled for multiple threads?
Hi Scott, I'm facing the same issue.
What do you mean when you say that the environment isn't enabled for multiple threads?
What should I do to fix it?
Thanks in advance
Thanks in advance
ADDENVVAR ENVVAR(QIBM_MULTI_THREADED) VALUE(Y) prior to runing QShell.
*if* that's the problem. IF not, then troubleshoot and determine the problem.
