HTTP_Post binding/security mismatch between the sender and the receiver
onie
Post by onie »
This is a SOAP API that I am working to write RPG program to process. V7R4M0 is the current version.
I am doing a HTTP_POST and getting the HTTP 500 error and below is the faultstring error.
Thanks for your advice and help! I am learning as I go with this project.
Onie
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelop ... <faultcode xmlns:a="http://schemas.microsoft.com/ws/2005/05 ... aultstring xml:lang="en-US">The message with Action 'https://tmwsytems.com/ AMS/IntegrationToolKit/SetFuelTicket' cannot be processed at the receiver, due to a ContractFilter mismatch at the EndpointDispatcher. This may be because of either a contract mismatch (mismatched Actions between sender and receiver) or a binding/security mismatch between the sender and the receiver. Check that sender and receiver have the same contract and the same binding (including sec
urity requirements, e.g. Message, Transport, None).</faultstring></s:Fault></s:Body></s:Envelope>
I have been able to get the API to run on Postman and SoapUI. I added the SoapAction string, but that didn't change anything.
My Post:
  rc = HTTP_POST(URL
                : SoapAddr
                : SoapLen
                : FILEPATH
                : TimeOut
                : *omit
                : *omit
                : SoapAction );               "
 "SOAP =
   '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap' +
   '.org/soap/envelope/" xmlns:ams="http://tmwsystems.com/AMS">' +
   '<soapenv:Header>' +
   '<ams:UserName>' + %trim(#UsrNme) + '</ams:UserName>' +
   '<ams:Password>' + %trim(#Pswd) + '</ams:Password>' +
   '</soapenv:Header>' +
   '<soapenv:Body>' +
   '<ams:SetFuelTicketParamMessage>' +
   '<ams:Param>' +
       '<ams:UnitId>' + %trim(#UnitId) + '</ams:UnitId>' +
       '<ams:ShopId>' + %trim(#ShopId) + '</ams:ShopId>' +
       '<ams:UnitNumber>' + %trim(#UnitNum) + '</ams:UnitNumber>' +
       '<ams:Vendor>' + %trim(#Vendor) + '</ams:Vendor>' +
       '<ams:BatchId>' + %trim(%editc(#BatchID: 'M')) + '</ams:BatchId>' +
       '<ams:FuelType>' + %trim(#FuelType) + '</ams:FuelType>' +
       '<ams:TicketNumber>' + %trim(#TicketNum) + '</ams:TicketNumber>' +
       '<ams:TripNumber>' +  %trim(#TripNum) + '</ams:TripNumber>' +
       '<ams:Quantity>' +  %trim(%editc(#Qty : 'M')) + '</ams:Quantity>' +
       '<ams:TotalAmt>' + %trim(%editc(#TotalAmt: 'M')) + '</ams:TotalAmt>' +
       '<ams:CreateDate>' + %trim(#CrtDate) + '</ams:CreateDate>' +
       '<ams:NotCompanyUnit>' + %trim(#false) + '</ams:NotCompanyUnit>' +
       '<ams:AmtUOM>' + %trim(#US$) + '</ams:AmtUOM>' +
       '<ams:TaxOverride>' + %trim(#false) + '</ams:TaxOverride>' +
       '<ams:Taxable>' + %trim(#false) + '</ams:Taxable>' +
       '<ams:ChgUOM>' + %trim(#US$) + '</ams:ChgUOM>' +
     '</ams:Param>' +
   '</ams:SetFuelTicketParamMessage>' +
  '</soapenv:Body>' +
  '</soapenv:Envelope>' ;
  SOAPAddr = %Addr(SOAP) + 2;
    SOAPLen = %Len(%Trim(SOAP));
    SoapAction = %trim(sAction);
RESPONSE:
OS/400 Ver V7R4M0
http_url_post(): entered
DNS resolver retry : 2
DNS default domain:xxxxxxxxx.com (x out name)
DNS server found: 10.1.5.14
DNS server found: 9.9.9.9
DNS server found: 8.8.4.4
https_init(): entered
QSSLPCL = *TLSV1.3 *TLSV1.2 *TLSV1.1 *TLSV1
initializing GSK environment
GSK Environment now available
SNI hostname set to: ave.tmwcloud.com
Cert Validation Code = 0
-----BEGIN CERTIFICATE-----
MIIGkDCCBXigAwIBAgIJAM1n/nloGgL4MA0GCSqGSIb3DQEBCwUAMIG0MQswCQYD
VQQGEwJVUzEQMA4GA1UECBMHQXJpem9uYTETMBEGA1UEBxMKU2NvdHRzZGFsZTEa
MBgGA1UEChMRR29EYWRkeS5jb20sIEluYy4xLTArBgNVBAsTJGh0dHA6Ly9jZXJ0 ( did not include all of this)
-----END CERTIFICATE-----
Serial Number: 00:CD:67:FE:79:68:1A:02:F8
Common Name: *.tmwcloud.com
Issuer CN: Go Daddy Secure Certificate Authority - G2
Issuer Country: US
Issuer State/Province: Arizona
Issuer Locality: Scottsdale
Issuer Org: GoDaddy.com, Inc.
Issuer Org Unit: http://certs.godaddy.com/repository/
Version: 3
not before: 20221218065335
Unknown Field: 06:53:35 18-12-2022
not after: 20240114084906
Unknown Field: 08:49:06 14-01-2024
Unknown Field: 0382010F003082010A0282010100CA6E3906D4165DEB
Unknown Field: 2048
Unknown Field: 2048
Unknown Field: 5F61A78D3D1F6D127D8655DFCAFE2CC0
Unknown Field: 63FED1CA56FF960148D8EE43030F93F375D7A26B
Unknown Field: 4FE8C61DFAAF5D646F712634F77426172BA49B059A3F809A1BCA3A76B87D701E
Unknown Field: 5
Unknown Field: *.tmwcloud.com
Unknown Field: 0
Unknown Field: 2.23.140.1.2.1
Unknown Field: 2.16.840.1.114413.1.7.23.1
Unknown Field: http://ocsp.godaddy.com/
POST /AMSApp/IntegrationToolKit/IntegrationToolKit.svc HTTP/1.1
Host: ave.tmwcloud.com
User-Agent: http-api/1.43
Content-Type: text/xml
SOAPAction: https://XXXsytems.com/ AMS/IntegrationToolKit/SetFuelTicket
Content-Length: 899
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns
HTTP/1.1 500 Internal Server Error
Date: Wed, 06 Sep 2023 11:34:44 GMT
Content-Type: text/xml; charset=utf-8
Content-Length: 757
Connection: keep-alive
Set-Cookie: ApplicationGatewayAffinityCORS=f027b2f5d7b4ac42faf47404f3ad4e56; Path=/; SameSite=None; Secure
Set-Cookie: ApplicationGatewayAffinity=f027b2f5d7b4ac42faf47404f3ad4e56; Path=/
Server: Microsoft-IIS/10.0
X-UA-Compatible: IE=Edge, Chrome=1
Strict-Transport-Security: max-age=157680000
SetError() #13: HTTP/1.1 500 Internal Server Error
recvresp(): end with 500
recvdoc parms: identity 757
cookie_parse() entered
cookie = ApplicationGatewayAffinityCORS=f027b2f5d7b4ac42faf47404f3ad4e56; Path=/; SameSite=None; Secure
cookie attr ApplicationGatewayAffinityCORS=f027b2f5d7b4ac42faf47404f3ad4e56
cookie attr Path=/
cookie attr SameSite=None
cookie attr Secure=
cookie attr Path=/
cookie attr Secure=
cookie = ApplicationGatewayAffinity=f027b2f5d7b4ac42faf47404f3ad4e56; Path=/
cookie attr ApplicationGatewayAffinity=f027b2f5d7b4ac42faf47404f3ad4e56
cookie attr Path=/
recvdoc(): Receiving 757 bytes.
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelop ... <faultcode (THE MESSAGE AT THE BEGINNING < ABOVE)
Re: HTTP_Post binding/security mismatch between the sender and the receiver
Something is different between what you are sending, and what the API expects.
Since you said you have this working in Postman and SoapUI, you should be able to compare what you are sending there with what is sent here and see what is different.
