MCH3601 - Pointer not set for location referenced
psteinmetz
Post by psteinmetz »
Receiving below MCH3601 errors - Pointer not set for location referenced.
Any thoughts from the group on what might be causing this.
V7R3-latest CUME and groups.
YAJL for IBM i - Version 10/14/20
Message ID . . . . . . : MCH3601 Severity . . . . . . . : 40
Date sent . . . . . . : 09/20/21 Time sent . . . . . . : 08:33:29
Message type . . . . . : Escape
From . . . . . . . . . : CPACOPER CCSID . . . . . . . . : 65535
From program . . . . . . . . . : YAJL
From library . . . . . . . . : SYS
From module . . . . . . . . : YAJL_TREE
From procedure . . . . . . . : yajl_obj_get
From statement . . . . . . . : 1
To program . . . . . . . . . . : YAJL
To library . . . . . . . . . : SYS
To module . . . . . . . . . : YAJL_TREE
To procedure . . . . . . . . : yajl_obj_get
To statement . . . . . . . . : 1
Time sent . . . . . . . . . . : 08:33:29.037372
Time zone abbreviated name . : EDT
Re: MCH3601 - Pointer not set for location referenced
Usual reason is just what it says ... you tried to use a pointer that has not been set.
Possible causes:
- Parameter that wasn't passed and not tested for
- Call to a YAJL function that returns a pointer that did not result in a "hit" and so the pointer was not set and then attempted to be used.
WIthout a code snippet or any indication of when/how this happens we're just guessing.
Was the program working and now stopped? New program?
It'd be very helpful if you showed us how to reproduce the problem.
Off the top of my head, I know I could DELIBERATELY create the same problem by doing the following:
    yajl_obj_find(*null: 'something');
But... Since we don't know what you are doing, it's hard to tell if that's what's happening in your case.
Frequently you'll see people get this error when they do something like this:
  "name": "Scott",
  "mailing address": {
     "street": "123 Sesame St"
  "billing address": {
shipAddr = yajl_obj_find(docNode: 'shipping address');
street = yajl_obj_find(shipAddr: 'street');
Since there is no 'shipping address' in the document, the first yajl_obj_find() will return *null. Then, it passes *null to the second yajl_obj_find(), which will result in the MCH3601.
If an element is optional, it's always better to code it like this:
if shipAddr = *null;
  Street = '';  // shipping address not found.
