Token not found yet setAuth seems working
Kyosukeh
Post by Kyosukeh »
First time trying auth with HTTAPI,
im using http_setauth(HTTP_AUTH_USRDFN:'Token':'MyToken')
then http_req('GET':%trim(url):*OMIT:response);
it look like the token and auth is set
but i got a http 200 response with Token not found,
when i try the same thing in SoapUI it work
Anyone got an idea ?
OS/400 Ver V7R3M0
https_init(): entered
QSSLPCL = *OPSYS
SSL version 2 support enabled
SSL version 3 support enabled
Support for TLS 1.3 unavailable.
initializing GSK environment
GSK Environment now available
http_setauth(): entered
DNS resolver retry  : 2
DNS default domain: S783BA00
DNS server found: 8.8.8.8
DNS server found: 8.8.4.4
SNI hostname set to: MYHOST
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----
MIIE9zCCA9+gAwIBAgISA5H0TFB1gMowsWBQTUaZfd62MA0GCSqGSIb3DQEBCwUA
-----END CERTIFICATE-----
Serial Number: 03:91:F4:4C:50:75:80:CA:30:B1:60:50:4D:46:99:7D:DE:B6
Common Name: *.dev.odoo.com
Issuer CN: R3
Issuer Country: US
Issuer Org: Let's Encrypt
Version: 3
not before: 20231211055521
Unknown Field: 05:55:21 11-12-2023
not after: 20240310055520
Unknown Field: 05:55:20 10-03-2024
Unknown Field: 0382010F003082010A02820101009CB1B626F22A380
Unknown Field: 2048
Unknown Field: 409CC7E9C83D7BBB95C330611ADBCAAC
Unknown Field: 956E5621328646DB0D25E76AB15436390F11B952
Unknown Field: 50D677EBC7536E5C450AA9966578C20B3CE6023A5B4
Unknown Field: 5
Unknown Field: *.dev.odoo.com
Unknown Field: 0
Unknown Field: 2.23.140.1.2.1
Unknown Field: http://r3.o.lencr.org
do_oper(GET): entered
GET /api/res.partner/162?api_key=MYAPI HTTP/
Host: MyHOST
User-Agent: http-api/1.45
Authorization: Token MyToken
Date: Fri, 12 Jan 2024 16:53:44 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 181
Connection: keep-alive
Strict-Transport-Security: max-age=600; includeSubDomains
Set-Cookie: session_id=364784e291713c05f1c2c837d32ea7eb6947a520; Expires=Sat, 11 Jan 2025 16:53:44 GMT; Max-Age=6
Server: Odoo.sh
SetError() £13: HTTP/1.1 200 OK
recvresp(): end with 200
recvdoc parms: identity 181
cookie_parse() entered
cookie =  session_id=364784e291713c05f1c2c837d32ea7eb6947a520; Expires=Sat, 11 Jan 2025 16:53:44 GMT; Max-Age=604
cookie attr session_id=364784e291713c05f1c2c837d32ea7eb6947a520
cookie attr Expires=Sat, 11 Jan 2025 16:53:44 GMT
cookie attr Max-Age=604800
cookie attr HttpOnly=
cookie attr Path=/
cookie attr Secure=
cookie attr SameSite=Lax
SetError() £0:
recvdoc(): Receiving 181 bytes.
{"success": true, "message": "Token not found", "responseCode": 200, "api_key": "XXXXX"
Re: Token not found yet setAuth seems working
I've not heard of 'Token' before. Did you mean Bearer?
 http_setauth(HTTP_AUTH_USRDFN:'Bearer':'MyToken')
Kyosukeh
Post by Kyosukeh »
Hi Scott
Yes, Token = Bearer
in my case the API use the word Token
thats why i used HTTP_AUTH_USRDFN
in soapUI i do this
Capture d’écran 2024-01-13 101146.png (230.55 KiB) Viewed 17426 times
Okay, it looks like they are using a completely separate header rather than the authorization one. As such, http_setAuth() is the wrong tool for the job.
You will need to write an "additional headers" exit procedure that adds the custom header.
Before calling http_req(), do this to tell it you want to add your own custom header:
 http_xproc( HTTP_POINT_ADDL_HEADER: %paddr(MyHeaders) );
When http_req() runs and is building the HTTP headers, it will now call MyHeaders. My headers can add the Token: header
 dcl-proc MyHeaders;
   dcl-pi *n;
     header varchar(5000);
   header = 'Token: ' + %trim(TheTokenValue) + x'0d25';
 end-proc;
Kyosukeh
Post by Kyosukeh »
Its working !
thanks a lot for the help (and the tool)
