Ms Sql server field DATETIME with JDBC_getCol
Scott Klement's open source interface to using JDBC database drivers from RPG. http://www.scottklement.com/jdbc/
alessandrotoninelli
Post by alessandrotoninelli »
accessing ms sql server with jdbcr4. I do a JDBC_ExecQry which returns the resultSet. iterating on the resultSet to the column that we will call "TIME" of type DATETIME the function JDBC_GetColC(rs:num_col) returns only the date part and not the time.
Example:
the column contains the data: 2014-01-22 08:40:52.500,
fieldTIME = JDBC_GetColC(rs:1) returns me only 2014-01-22
This the code:
      enval = '/home/alext/java/jdbc/mssql-jdbc-12.6.0.jre8.jar';
       putenv('CLASSPATH='+enval:qusec);
       prop = JDBC_Properties();
       JDBC_setProp(prop: 'user'     : 'user');
       JDBC_setProp(prop: 'password'     : 'password');
       JDBC_setProp(prop: 'database' : 'dbMhs0997');
       JDBC_setProp(prop: 'encrypt' : 'false');
       JDBC_setProp(prop: 'trustServerCertificate' : 'false');
       conn = JDBC_ConnProp(
      'com.microsoft.sqlserver.jdbc.SQLServerDriver'
                             :'jdbc:sqlserver://192.168.0.20:50690'
                             : prop );
       JDBC_freeProp(prop);
       if (conn = *NULL);
           snd-msg 'Not connected';
          rs = JDBC_ExecQry(conn:'SELECT top 1 * FROM dtLu');
          if rs = *null;
             JDBC_close(conn);
          dow JDBC_NextRow(rs);
            fieldTIME = JDBC_GetColC(rs:1);
            snd-msg 'field: '+fieldRs;
          enddo;
          JDBC_FreeResult(rs);
          JDBC_close(conn);
       JDBC_close(conn);
i used both mssql-jdbc-12.6.0.jre8.jar and jtds-1.3.1.jar
