I've just updated our 1.45 install to 1.48 (from the save file download) and noticed that the README file in QRPGLESRC is missing content beyond the 100 character SRCDTA size. I presume it's from the switch to using the IFS for source members introduced in 1.46, with lines being truncated when packaged for the save file.
It's not exactly a world-ending issue, but it is the only one we've had using HTTPAPI so far! We're using http_req() to interact with Sage Intacct web services and it worked on the first try. It's my first time using web services from RPG and I'm appreciating the XML-INTO opcode (which I read about in one of your presentations https://www.scottklement.com/presentations/#HTTPAPI). It makes it all quite easy
Thanks for your hard work on this project.
Regards, Martin
