I received a new request to send files via sFTP to a new trading partner.
After copying a previous setup, and changing the scripts, I continue to get Permission Denied.
Key is in /home/skxftp/.ssh
- myftp.dachser.com,195.145.171.89 ecdsa-sha2-nistp256 AAAAE.......
The script is stored in /home/skxftp/Src/dac_sftp_script.sh
- #!/bin/sh
- export DISPLAY= SSH_ASKPASS=/QOpenSys/etc/Dac_password_script.sh
- printf "lcd /Home/Skxftp/Out/Dac/\ncd /data/edi/da00127976/in\nput *.csv\nquit\n" | sftp -vvv -oStrictHostKeyChecking=no
-oPasswordAuthentication=yes USER001@myftp.dachser.com
The password is stored in /QOpenSys/etc/Dac_password_script.sh
- #!/bin/sh
- printf PASSWORD001
I constantly get the read_passphrase: can't open /dev/tty: No such device or address!!!
This setup works well with other partners.
What should i be checking, or have the partner check?
Thanks in advance.
Chris
Batch CL for sFTP with Password Authentication
cea_1964@yahoo.com
Re: Batch CL for sFTP with Password Authentication
On Unix systems, "tty" (teletype) is synonymous with "terminal". So what this error message is telling you is that it's trying to read the password from the terminal -- and it can't because there is no terminal associated with your session.
This tells me that, for some reaon, SSH_ASKPASS i not working in this script. If it were working, it'd get the password from that script instead of the terminal.
I don't know why SSH_ASKPASS isn't working -- I'm not familiar with SSH_ASKPASS.
But, this definitely doesn't seem to have anything to do with the partner. The problem is completely on your side of the connection.
cea_1964@yahoo.com
Do you think the Expect tool would resolve my issue?
cea_1964@yahoo.com
Also, the key added to our known host was an id_ecdsa. Should i also have an id_ecdsa key pair in .ssh?
cea_1964@yahoo.com
I have it working.
The password contained a "$", which was sending some type control break, or being converted, or.......whatever.
In the log, I noticed the password was truncated at the position where the "$" was located. So, I put single quotes around the pw in the password script .sh file. Viola!!!
Thanks, and hope to see you soon.
Chris
Chris
The $ character has a special meaning in a shell script, so to put a $ in your SSH_ASKPASS script you would need to escape it properly.
