Configuration Kyocera MA 3005 (color)
gio.cot
Post by gio.cot »
Hi all
I need to configure Kyocera MA 3005 IBM to print with Colored overlay ;
below the configuration that with Blank and withe Overlay works; instead with Colored overlay i receive CPF3397 and the writer ends
Can some help to configure so that also with Colored overlay it works?
Thanks in advance
Pheraps i'm wrong on creating Color Overlay ??
Actual configuration
Unit description . . . . . . . . : DEVD PRTES
Option . . . . . . . . . . . . . : OPTION *ALL
Unit category . . . . . . . : *PRT
Unit class . . . . . . . . . . . : DEVCLS *LAN
Unit type . . . . . . . . . . . . : TYPE 3812
Unit model . . . . . . . . . . : MODEL 1
LAN connection . . . . . . . . . : LANATTACH *IP
Port number . . . . . . . . . . . : PORT 9100
Physical connection . . . . . . . : ATTACH *DIRECT
Inline to IPL . . . . . . . . . . : ONLINE *YES
Font . . . . . . . . . . . . : FONT
Identifier . . . . . . . . . : 011
Size in points . . . . . . : *NONE
Formfeed . . . . . : FORMFEED *AUTOCUT
Drawer for separators . . . . . : SEPDRAWER *FILE
Separator program . . . . . . . : SEPPGM *NONE
Library . . . . . . . . . . . . :
Printer error message . . : PRTERRMSG *INQ
Message queue . . . . . . . . . . : MSGQ *CTLD
Current message queue . . . . . . : QSYSOPR
Library . . . . . . . . . . . . : QSYS
Date of last activity . . . . . . . :
Activation timer . . : ACTTMR 170
Inactivity timer . . . . : INACTTMR *SEC15
Line speed . . . . . . . : LINESPEED 19200
Word length . . . . . . . . . : WORDLEN 8
Parity type . . . . . . . . . . : PARITY *
Stop bits . . . . . . . . . . : STOPBITS 1
Transform print host . . . : TRANSFORM *YES
Manufacturer type and model . . : MFRTYPMDL *HP4
Paper origin 1 . . . . . . . . . : PPRSRC1 *A4
Paper origin 2 . . . . . . . . . : PPRSRC2 *A4
Origin of envelopes . . . . . . . : ENVELOPE *NUMBER10
899 ASCII codepage support . . . : ASCII899 *NO
Image configuration . . . . : IMGCFG *NONE
Character identifier . . . . . : CHRID *SYSVAL
Remote location . . . . . . : RMTLOCNAME
Name or address . . . . . . . . : 192.xx
Ogg. personaliz. workstation . . : WSCST *NONE
User-defined object . . . : USRDFNOBJ *NONE
Object type . . . . . . . . . . : *NONE
Data conversion program . . : USRDTATFM *NONE
System control prog. . . . . : SYSDRVPGM *IBMSNMPDRV
Assigned to:
Job name . . . . . . . . . . . : QSYSARB
User . . . . . . . . . . . . . : QSYS
Number . . . . . . . . . . . . . : 324505
Published . . . . . . . . . . . . : *NO
Unit description . . . . . . . . : DEVD PRTES7170W
Publication information . . : PUBLISHINF
Duplex support . . . . . . . . : *UNKNOWN
Support color . . . . . . . . : *UNKNOWN
Black pages per minute . . . . . : *UNKNOWN
Color pages per minute . . . . : *UNKNOWN
Location . . . . . . . . . . . : *BLANK
Supported data streams . . . : *UNKNOWN*ALL
Re: Configuration Kyocera MA 3005 (color)
  • CPF3397 text says "See the job log of the writer". Did you do that? What did you learn?
  • Last time I researched it, Host Print Transform did not support color overlays. Did that change? (This wouldn't cause the writer to end, but if it worked, the overlay would be black & white)
  • You have configured as *HP4, which if I recall, was a black & white laser printer from the 1990s. So again, if it works, it's going to be black & white, not color.
