GSK trace
RBlanco
GSK trace
Post by RBlanco »
What is required to do a GSK trace?  I read the following information.
"In order to capture trace information using environment variables, the trace environment variables GSK_TRACE and GSK_TRACE_FILE must be exported before the start of the SSL application."
I tried the following commands before running the RPG program using GSK API's but it did not create a trace file.
ADDENVVAR ENVVAR(GSK_TRACE) VALUE('0xffff')
ADDENVVAR ENVVAR(GSK_TRACE_FILE) VALUE('/tmp/gskssl.%.trc')
Also, from what I read; a trace file must be formatted.  What is the corresponding IBM i command for the following command?  Or I need to run it in SSH terminal?
 gsktrace input_trace_file > output_trace_file
Thank you.
