kjarrig
Posts: 6 Joined: Tue Apr 18, 2023 8:31 am
Post
by kjarrig » Mon May 27, 2024 10:58 am
I have a xmldata
<FtsSkilagrein>
<Greidandi>
<Tolvupostfang>noreply@ss.is</Tolvupostfang>
<Vidtakandi>
<Kennitala>XXXXXXX</Kennitala>
<Fjarmagnstekjur>
<UpprunaAudkenni>XXXXXXX</UpprunaAudkenni>
<Tegund>Vextir</Tegund>
<Undirtegund>Stofnsjóður</Undirtegund>
<Tekjur>36566</Tekjur>
<Stadgreidsla>8045</Stadgreidsla>
</Fjarmagnstekjur>
</Vidtakandi>
<Vidtakandi>
When I use the base64_encode I get the result
TMajouKSiZOBh5mFiZVuJUzHmYWJhIGVhIluJUzjlpOlpJeWoqOGgZWHbpWW
mYWXk6isoqJLiaJMYeOWk6Wkl5aio4aBlYduJUzliYSjgZKBlYSJbiVM0oWV
lYmjgZOBbvb38Pj49vHz8flMYdKFlZWJo4GTgW4lTMaRgZmUgYeVoqOFkpGk
mW4lTOSXl5mklYHBpISShZWViW729/D4+Pbx8/H5TGHkl5eZpJWBwaSEkoWV
lYluJUzjhYeklYRu5YWno4mZTGHjhYeklYRuJUzklYSJmaOFh6SVhG7io5aG
laKRznmkmUxh5JWEiZmjhYeklYRuJUzjhZKRpJlu8/b19vZMYeOFkpGkmW4l
instead of
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
The part of the code is:
dcl-s xmldata varchar(1500000); // ccsid(1208);
dcl-s Xmlencode64 like(xmlData);
Dcl-s xmlPointer pointer;
Dcl-s xmlLength int(10:0);
dcl-s xmlOutput pointer;
dcl-s xmlOutputlen int(10:0);
xmldata = %str(xmlPointer:xmlLength);
xmlOutputlen = %len(xmlEncode64: *max);
xmlOutput = %addr(Xmlencode64: *data);
wwEnclen = base64_encode(xmlPointer:xmlLength:
xmlOutput : xmlOutputlen);
Xmlencode64 = %str(xmlOutput: xmlOutputlen);
I'm quite lost why I don't get the right result with the base64_encode function. Any help is greatly appriciated.
Posts: 246 Joined: Wed Jul 28, 2021 8:18 pm
Post
by jonboy49 » Mon May 27, 2024 10:52 pm
I'm still wrestling with Base64 and RPG myself but ...
The simple answer is that you are encoding an EBCDIC string and expecting the results to match that of performing the same task with ASCII or UTF-8.
Base64 encoding is designed to preserve a _binary_ pattern. Which we can see most easily as hex. The string "<xmlstuff>" is represented in hex as shown below for UTF-8 and EBCDIC. As you can see they are very different and will produce different results. Since you are probably communicating with a system using UTF-8 the data needs to be in that form in your RPG program. See the code sample below which is loosely based on yours. You will see that the results will be what you expect. Whether you need to convert the output to UTF-8 depends on what you are going to do with it.
UTF8Data: 3C 78 6D 6C 73 74 75 66 66 3E
ebcdicData: 4C A7 94 93 A2 A3 A4 86 86 6E
**Free
ctl-opt bnddir('BASE64/BASE64BND');
/copy base64/qrpglesrc,base64_h
dcl-s UTF8Data varchar(1000) ccsid(1208)
inz('<xmlstuff>value here</xmldata>');
Dcl-s ebcdicData char(30)
dcl-s encoded char(45);
dcl-s wait char(1);
dcl-s outputlen int(10:0);
outputlen = base64_encode( %addr(UTF8Data:*data)
: %Len(UTF8Data)
: %addr(encoded)
: %Len(encoded) );
Dsply ('Data: ' + encoded ) ' ' wait;
Note that I only put ebcdicData in the program so I could see the hex values in debug.
kjarrig
Post
by kjarrig » Tue May 28, 2024 2:05 pm
Thanks jonboy49, you got me on right track
