JSON array without a named tag
AddiedePinho
Post by AddiedePinho »
The JSON received does not have a named tag for the arrays "properties"
there are no key value pairs in the properties list.
How do i need to setup my data structure to handle this?
this is the input (oRestExp.Response)
    "id": "6655d1976079af00011c931b",
    "isBankAccountValid": true,
    "bankAccount": {
        "failedValidations": [],
        "properties": [
            "ACCOUNT_ACCEPTS_CREDITS",
            "ACCOUNT_ACCEPTS_DEBITS",
            "ACCOUNT_OLDER_THAN_THREE_MONTHS"
    "bankAccountHolder": {
            "FAMILY_NAME_MISMATCH"
dcl-ds VerifyResponse  qualified;
   id                    char(100);
   isBankAccountValid    ind;
   dcl-ds bankAccount;
      num_failedValidations  int(10);
      dcl-ds  failedValidations  dim(10);
      num_properties        int(10);
      dcl-ds properties  dim(10);
   dcl-ds bankAccountHolder;
data-into VerifyResponse %DATA(oRestExp.Response:
                  'case=convert +
                  allowmissing=yes +
                  allowextra=yes +
                  countprefix=num_')
                  %PARSER('YAJLINTO');
the output VerifyResponse:
VERIFYRESPONSE.ID =
1 '6655d1976079af00011c931b '
61 ' '
VERIFYRESPONSE.ISBANKACCOUNTVALID = '1'
VERIFYRESPONSE.BANKACCOUNT.NUM_FAILEDVALIDATIONS = 1077952576
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(1) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(2) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(3) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(4) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(5) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(6) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(7) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(8) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(9) = ' '
VERIFYRESPONSE.BANKACCOUNT.FAILEDVALIDATIONS(10) = ' '
VERIFYRESPONSE.BANKACCOUNT.NUM_PROPERTIES = 1077952576
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(1) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(2) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(3) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(4) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(5) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(6) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(7) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(8) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(9) = ' '
VERIFYRESPONSE.BANKACCOUNT.PROPERTIES(10) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.NUM_FAILEDVALIDATIONS = 1077952576
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(1) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(2) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(3) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(4) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(5) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(6) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(7) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(8) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(9) = ' '
VERIFYRESPONSE.BANKACCOUNTHOLDER.FAILEDVALIDATIONS(10) = ' '
Re: JSON array without a named tag
Don't have time to play with this - supposed to be on vacation ...
At first glance "properties" should just be an array not a DS.
So this:
     properties   varchar(50)   dim(10);
both properties and failedValidations should be arrays of character strings, not arrays of data structures.
AddiedePinho
Thank you for the reply.
I made the change, and it works
