Little endian to big endian UTF-16 conversion
peder udesen
Post by peder udesen »
Receiving a file in UTF-16 little endian from a Windows on an as/400 ( formerly known as ) gives a practical problem
that the as/400 only can handle UTF-16 big endian ( CCSID(1200) ).
As far as I can see UTF-16 little endian ( CCSID(1202) ) is not supported here.
The question is: Is it enough to create a program that reads 2 bytes from the UTF-16LE file, swaps the bytes and writes
the 2 bytes to a file that then should be in UTF-16BE format. Of course reading and writing if pure binary.
Something like this in pseudo code
open UTF-16LE input  binary mode
open UTF-16BE output binary mode
read 2bytes from UTF-16LE
dow not eof(UTF-16LE)
  swap(2bytes)
  write 2bytes to UTF-16BE
enddo
close UTF-16LE
close UTF-16BE
And then finally change the CCSID on UTF-16BE to 1200
Re: Little endian to big endian UTF-16 conversion
That sounds correct to me. It should work.
There is also the "Transform UCS Data" API that could potentially be used. https://www.ibm.com/docs/api/v1/content ... gtrans.htm
