yajl_h and full free for RPG program ?
richardschoen
Post by richardschoen »
Hi Scott or anyone else,
I have a program I'm trying to convert to full free form RPG and it doesn't like the yajl_h header file because it's not full free form.
Is there a way to compile with the included yajl_h fill without reverting back to non full free form ?
Or has anyone converted the yajl_h header to be entirely free form RPG ?
Thoughts appreciated.
Regards
Richard Schoen
Re: yajl_h and full free for RPG program ?
richardschoen wrote: Wed Sep 18, 2024 6:49 pm I have a program I'm trying to convert to full free form RPG and it doesn't like the yajl_h header file because it's not full free form.
I don't agree with you. That's not how RPG works -- it does not reject copybooks because they aren't fully-free format. It will automatically work with a fixed format copybook in a fully-free program.
I've done this a zillion times. Plus, that's how it's documented to work.
I think you are likely having a completely different problem and are incorrectly attributing it to the format of the source.
Yes, just use the existing copybook from your fully-free program, it will work fine.
richardschoen
OK thanks for confirming it should work.
I was going to come chat with you this morning at your JSON session but I slept in.
