Upgrading from V7R1 to V7R3 - HTTPAPI Compatibility?
Metatpon
Post by Metatpon »
Hi all
As the subject says - we're upgrading our OS to V7R3 and I've never worked with HTTPAPI before. I was wondering if there are any version compatibilities out there that I need to be aware of. I've seemed to find some conflicting information while searching elsewhere and haven't been able to locate version directories.
It looks like we are on Version 1.23
Can anyone help me figure this out?
brianjgarland
Contact:
Re: Upgrading from V7R1 to V7R3 - HTTPAPI Compatibility?
Post by brianjgarland »
I have used HTTP API on IBM i 7.3 daily with no issues for at least 2 years now.
1.23 is pretty old. You may want to update just to be current.
Metatpon
Post by Metatpon »
Thanks for the reply. Possibly dumb question - where can I go to get a more recent version?
brianjgarland
Contact:
All of Scott's utilities are at scottklement.com
You can get HTTP API at scottklement.com/httpapi/
Metatpon
Post by Metatpon »
Great, thank you very much!
