DATA-Into for JSON
bobgentile
DATA-Into for JSON
Post by bobgentile »
I have read everything and I still can not get this JSON to load into the RPG Program is should be loading but I keep getting the error mesage
Preparation for XML parsing failed with message CPE3025
Here is the code
dcl-ds claim_data qualified;
           ClaimNumber      zoned(10);
           DateReported      char(32);
           dcl-ds Insured;
             L1_PolicyNumber     char(20);
             L1_PolicyType       char(3);
             L1_LoanNumber       zoned(7);
             L1_CompanyNumber    zoned(5);
             L1_CustomerNumber   zoned(7);
             L1_TransferCode     zoned(1);
             L1_PolicyStartDate  char(10);
             L1_PolicyExpireDate char(10);
             L1_FirstName        char(25);
             L1_LastName         char(30);
             L1_HomePhone        char(10);
             L1_LocationAddress1 char(40);
             L1_LocationAddress2 char(40);
             L1_LocationCity     char(26);
             L1_LocationState    char(2);
             L1_LocationZip      char(10);
             L1_LocationCountry  char(3);
             L1_LocationCounty   char(30);
             L1_MailingAddress1  char(40);
             L1_MailingAddress2  char(40);
             L1_MailingCity      char(26);
             L1_MailingState     char(2);
             L1_MailingZip       char(10);
             L1_MailingCountry   char(3);
           dcl-ds Loss;
             L2_TemporaryClaimNumber  zoned(10);
             L2_LossType          char(10);
             L2_DateOfLoss        char(10);
             L2_ReportedBy        char(40);
             L2_LivingInHome      char(75);
             L2_Whereabouts       char(75);
             L2_AdditionalCoverage char(75);
             L2_OtherPhone         char(10);
             L2_OtherPhoneExt      char(6);
             L2_OtherPhoneCont     char(30);
             L2_Email              char(50);
             L2_PoliceOrFireDepartment  char(20);
             L2_CalledBy           char(30);
             L2_DetailsOfLoss      char(700);
             L2_PersonalEffectsDamage char(1);
             L2_AdjStructureDamage    char(1);
             dcl-ds Claimant;
             L3_Name               char(30);
             L3_Address1           char(40);
             L3_Address2           char(40);
             L3_City               char(26);
             L3_State              char(2);
             L3_Zip                char(10);
             L3_Country            char(3);
             L3_HomePhone          zoned(10);
             L3_WorkPhone          zoned(10);
             L3_Age                zoned(3);
             L3_DateOfBirth        char(10);
             L3_Employer           char(30);
             L3_Position           char(30);
             L3_SpanishSpeaker     char(5);
             L3_AdditionalComments char(700);
         dcl-s json_file_path  char(100);
         json_file_path = '/policy/homeowners/inbound/LossReport_2400005552';
         data-into claim_data %data(json_file_path : 'case=any +
                                  allowMissing=yes +
                                  allowExtra=yes +
                                  doc=file')
         %parser('YAJLINTO' : '{"document_name": json_file_path} ');
Re: DATA-Into for JSON
Type this;
DSPMSGD CPE3025
What does the message say?
bobgentile
I have done that already, I get no such path of directory , but the path does exist. see below
mlazarus
Post by mlazarus »
You don't have the .json extension in your path/file name.
bobgentile
Adding the .json to the end resolved the CPE3025 error now I am getting a error in the parsing
Message . . . . : Error CPF9897 occurred while running the program or
procedure for the DATA-INTO operation.
Cause . . . . . : Program or procedure 'YAJLINTO' for the DATA-INTO
operation failed with error message CPF9897. *N indicates that the program
or procedure is a procedure pointer.
Recovery . . . : Check the job log for a complete description of message
CPF9897, and contact the person responsible for program maintenance.
Job Log Message
1004: Parser options are not valid JSON!
Error CPF9897 occurred while running the program or procedure for the
Unmonitored exception at line 115
bobgentile
What is missing or wrong, with no answer from anyone did I actual come across and error no knows about. Find this hard to believe
This is not valid:
This code makes no sense at all. It isn't valid JSON. I think your intent was to put the IFS pathname here, but... that isn't what this option is for. This is the name of the document element within your JSON, not a file name.
Unless there's something going on here that you haven't explained, you don't need this. Just do this:
%parser('YAJLINTO');
