Object containing the password for the certificate store file not found.
peder udesen
Post by peder udesen »
I have just changed the server from http to https in my program.
It has worked OK as long as I used the http protocol.
Only the constant http://myServer in my program was changed to https://myServer and the program was compiled OK.
myServer is of course changed to use the https protocol.
Now I get the error:
And I can't figure out what I'm doing wrong or missing.
Can you help me?
The log is as follows:
HTTPAPI Ver 1.49 released 2024-04-16 <=== this is actually 1.51
OS/400 Ver V7R5M0
https_init(): entered
QSSLPCL = *OPSYS
initializing GSK environment
(GSKit) Object containing the password for the certificate store file not found.
ssl_error(201): (GSKit) Object containing the password for the certificate store file not found.
SetError() #24: gsk_env_init: (GSKit) Object containing the password for the certificate store f
peder udesen
Re: Object containing the password for the certificate store file not found.
We have located the cause.
It turned out that the *SYSTEM certificate store was corrupt.
After deleting it and creating it again everything worked like a charm.
Regards
Peder
