Hello everyone,
I'm receiving a JSON as a parameter in this format:
The parameter will be received in the program as a long string.
"matricule": 258,
"plateforme": "DT",
"specifFonction": "XP3",
"palettes": [
"ssccr": "31623311010770289",
"codeEmballageSR": "6311930",
"typeDestinataire": "A",
"codeDestinataire": "30530",
"emballagesSupp": [
{ "code": "6311799", "qteEmballage": 1 },
{ "code": "6311211", "qteEmballage": 3 }
"count": 2
"ssccr": "31623311010770290",
"codeDestinataire": "30531",
"emballagesSupp": [
"count": 2
"count": 2
So I'd like to insert this JSON into a DS. I think YAJL can do it.
Do you have a code example in free-form to help me?
Thank you
Transferring a JSON via Parameter into a DS
Oliver_superU
Oliver_superU
Re: Transferring a JSON via Parameter into a DS
this my code
but not compiling on the Data-Into
*#C CRTSQLRPGI DBGVIEW(*SOURCE) OBJ(
**FREE
Ctl-opt Debug Datedit(*YMD) DFTACTGRP(*NO) actgrp(*new) bnddir('YAJL')
option(*srcstmt: *nodebugio: *noshowcpy);
/copy yajl_h
Dcl-ds EmballageSupp_t Qualified Template;
code VarChar(20);
qteEmballage Int(10);
End-ds;
Dcl-ds Palette_t Qualified Template;
ssccr Char(20);
codeEmballageSR VarChar(20);
typeDestinataire Char(1);
codeDestinataire VarChar(10);
num_emballagesSupp Int(5);
emballagesSupp Likeds(EmballageSupp_t) Dim(20);
count Int(5);
End-ds;
Dcl-ds MatriculeInfo_t Qualified Template;
matricule Int(10);
plateforme VarChar(20);
specifFonction VarChar(20);
num_palettes Int(5);
palettes Likeds(Palette_t) Dim(50);
count Int(5);
End-ds;
// Déclaration de la structure de données principale pour stocker le JSON parsé
Dcl-ds MonJsonDs Likeds(MatriculeInfo_t);
// Variables de travail
Dcl-s pJsonInput Varchar(32767); // Simule le paramètre JSON entrant
Dcl-s JsonData Pointer; // Pointeur pour la mémoire allouée dynamiquement
Dcl-s JsonLen Int(10); // Longueur réelle de la chaîne JSON
Dcl-s i Int(10); // Compteur pour la boucle des palettes
Dcl-s j Int(10); // Compteur pour la boucle des emballages sup
// Simulation du JSON reçu en paramètre
// En réalité, 'pJsonInput' serait un paramètre de procédure/programme.
pJsonInput = '{ "matricule": 258, "plateforme": "DT", "specifFonction": "XP3", +
"palettes": [ {"ssccr": "31623311010770289", +
"codeEmballageSR": "6311930", "typeDestinataire": "A", +
"codeDestinataire": "30530", "emballagesSupp": +
[ { "code": "6311799", "qteEmballage": 1 }, { "code":"6311211", +
"qteEiballage": 3 } ], "count": 2 }, +
{ "ssccr": "31623311010770290", "codeEmballageSR":"6311930", +
"typeiestinataire": "A", "codeDestinataire": "30531", +
"emballagesSupp": [ { "code":"6311799", "qteEmballage": 1 }, +
{ "code": "6311211", "qteEmballage": 3 } ], "count": 2 } ], "count":2 }';
// Allouer de la mémoire pour le JSON reçu
JsonLen = %Len(pJsonInput);
JsonData = %Alloc(JsonLen);
// Copier le contenu du paramètre simulé dans la mémoire allouée
%Str(JsonData:JsonLen) = pJsonInput;
// Utilisation de DATA-INTO pour mapper le JSON à la structure de données principale
Data-Into MonJsonDs
%Data(JsonData: JsonLen)
%Parser('YAJLINTO' : 'case=lower + allowextra=yes + countprefix=num_');
Return;
**FREE
/copy yajl_h
code VarChar(20);
End-ds;
ssccr Char(20);
count Int(5);
End-ds;
matricule Int(10);
count Int(5);
End-ds;
Data-Into MonJsonDs
Return;
Try using the YAJLGEN command that comes with YAJL, it will help you get started in defining your data structure.
I don't understand why you are using pointers and %ALLOC and similar things, this doesn't make any sense in this context.
