DATA-INTO Question
emhill
DATA-INTO Question
Post by emhill »
I have my DATA-INTO data structure created like this:
dcl-ds jsonDoc qualified;
  STATUS varchar(10) inz('');
  MESSAGE varchar(50) inz('');
  INTERFACENAME varchar(50) inz('');
  num_BATCHCLAIMRESPONSE int(10) inz(0);
  dcl-ds BATCHCLAIMRESPONSE dim(150);
    dcl-ds CLAIMINFO;
      TRACKINGNUMBER varchar(10) inz('');
      SUBMITTALINDICATOR varchar(1) inz('');
      SERIALNUMBER varchar(20) inz('');
      RMASTATUSDESCRIPTION varchar(80) inz('');
      RMASTATUSCODE varchar(3) inz('');
      REPAIRORDER varchar(8) inz('');
      REPAIRINGOUTLET varchar(10) inz('');
      IDENTIFIER varchar(50) inz('');
      DISPOSITIONCODEDESCRIPTION varchar(80) inz('');
      DISPOSITIONCODE varchar(5) inz('');
      DATETIMEPROCESSED varchar(24) inz('');
      CLAIMSTATUSDESCRIPTION varchar(20) inz('');
      CLAIMSTATUSCODE varchar(3) inz('');
      num_CLAIMPROCESSMSGINFO int(10) inz(0);
      dcl-ds CLAIMPROCESSMSGINFO dim(300);
        LINENUMBER varchar(5) inz('');
        PROCESSCODE varchar(4) inz('');
        PROCESSCATEGORYDESCRIPTION varchar(20) inz('');
        PROCESSMESSAGE varchar(80) inz('');
      CLAIMNUMBER varchar(20) inz('');
      APPROVEDDOLLARAMOUNT varchar(20) inz('');
    BUSINESSPARTNERCODE varchar(10) inz('');
This is my DATA-INTO statement:
data-into jsonDoc %DATA( ifsPathname
         : 'doc=file case=convert countprefix=num_ allowextra=yes')
                %PARSER( 'YAJLINTO'
                       : '{ "document_name": "jsonDoc", +
                            "number_prefix": "YAJL_" }');
All works well until I get the following response for my request where a claim number "posted" is invalid:
  "status": "Success",
  "message": "Claim not Found",
  "interfaceName": "I-207 - Batch Claim Submittal Response",
  "batchClaimResponse": null
How do I handle that error in the DATA-INTO statement? Would the 'allowmissing=yes' option and then checking the 'num_BATCHCLAIMRESPONSE' value for zero? Or do I need a monitor wrapped around the statement?
Thanks!!!!
Re: DATA-INTO Question
RPG (including DATA-INTO) expects the data type of variables to be set at compile time, and not changed after it has been compiled.
As such BatchClaimResponse can't be both null AND a data structure. It must be one or other... DATA-INTO really only works if the fields are always the same type. If they are sometimes data structures, and sometimes something else (like null) it doesn't work very well.
So... no... allowmissing=yes won't help, because the field isn't missing! Checking the count of batchClaimResponse for 0 won't work, because the document doesn't contain 0 -- it contains 1. ( But, the one sent is null.)
One way to handle this would be to use the YAJL subprocedures instead of DATA-INTO. That will be able to check the contents of the batchClaimResponse to see if it's null without problems.
