HTTP_POST_XML error with no/empty response
mfef
Post by mfef »
Hi everybody,
on successful invocation of an asynchronous http-interface, error 66 "XML parse failed at line 1, col 0: no element found" is displayed with RC = -1.
The server returns HTTP 200, there is no response, that's correct. The call is properly processed.
call:
      /FREE
         msg = '<?xml version="1.0" encoding="iso-8859-1" standalone="no"?>' +
               '<ns0:MT_ZISHPOS_PACKAGE xmlns:ns0="http://ef.de/ishop">' +
               '<packageNr>' + %CHAR(packageNr) + '</packageNr>' +
               '</ns0:MT_ZISHPOS_PACKAGE>';
      /END-FREE
     C                   CALLP     http_debug(*ON: '/tmp/INT955.txt')
      /FREE
         resultRC = HTTP_POST_XML(
                      soapUrl
                      :%ADDR(msg) + 2
                      :%LEN(msg)
                      :*NULL
                      :*NULL
                      :*NULL
                      :wkTIMEOUT
                      :wkUSERAGENT
                      :'application/xml'
                      :*omit);
      /END-FREE
debug-log
OS/400 Ver V7R4M0
<?xml version="1.0" encoding="iso-8859-1" standalone="no"?><ns0:MT_ZISHPOS_PACKAGE xmlns:ns0="http://ef.de/ishop"><packageNr>42092</packageNr></ns0:MT_ZISHPOS_PACKAGE>
server: SAP NetWeaver Application Server 7.53 / AS Java 7.50
date: Mon, 10 Jan 2022 12:30:00 GMT
content-length: 0
set-cookie: saplb_*=(J2EE802193320)802193350; Version=1; Path=POD; Secure; HttpOnly
recvresp(): end with 200
recvdoc parms: identity 0
cookie_parse() entered
cookie =  saplb_*=(J2EE802193320)802193350; Version=1; Path=POD; Secure; HttpOnly
cookie attr saplb_*=(J2EE802193320)802193350
cookie attr Version=1
cookie attr Path=POD
cookie attr Secure=
cookie attr HttpOnly=
cookie rejected, path/dom doesn't match request.
recvdoc(): Receiving 0 bytes.
OS/400 Ver V7R4M0
SetError() #66: XML parse failed at line 1, col 0: no element found
Can anyone tell me why it is trying to parse the empty response?
Re: HTTP_POST_XML error with no/empty response
That's what HTTP_POST_XML does... it parses the response with an XML parser.
Use HTTP_POST (or a newer option like http_req) if you don't want it to try to parse the response.
