PUT with If-Match Header?
heimo
Post by heimo »
I'm using HTTPAPI to syncronize different Databases.
Now I need to send Header-Informations with the PUT-Command.
Example:
PUT /SYSTEM/ODataV4/Company('COMP')/Customer('123456')
If-Match: W/"440112715"
With "POSTMAN" there is an own categorie "Headers" - but how to implement this in RPG ?
I use:
Response = http_string('PUT':URLCust:DataU:'application/json');
Re: PUT with If-Match Header?
Basically you will need to use http_xproc to declare the procedure to add the custom headers. This is called _before_ you call the http_... function to invoke the web service. The http API will then call your routine while building the request.
Here's a snippet of what I use to invoke Zoom APIs.
                : %paddr(addSpecialHeaders)
                : %addr(authorizationToken) );
 Dcl-Proc addSpecialHeaders;
   Dcl-Pi *N;
      headersToAdd    Varchar(32767);
      var             like(authorizationToken) const;
   End-Pi;
   Dcl-c  CRLF  x'0d25';
   headersToAdd = 'authorization: ' + var + CRLF;
End-Proc;
heimo
Post by heimo »
hey jonboy49!
thnx very much - it helped.
