http_req with POST and large string
belstsrv
Post by belstsrv »
I am trying to send a large string using http_req but the receiving side is only getting 64K of the string. Using the same string in Postman results in the whole string arriving OK.
My HTTPAPI version is 1.42. My code snippets are below. The large variable is "body" and is defined as shown.
D body            s        5000000a   varying
formData = 'req_client='  + %trim(clientcode)
         + '&req_uri='    + %trim(url)
         + '&req_method=' + %trim(method)
         + '&req_body='   + %trim(body);
http_setOption( 'content-type'
              : 'application/x-www-form-urlencoded' );
rc = http_req( 'POST'
             : authURL
             : *omit                      // File to receive
             : response                   // String to receive
             : *omit                      // File to send
             : formData );                // String to send
I am wondering if something with the URL encoded form is causing the data to be truncated?
All variables seem large enough so I am not certain where else to look. I also am not able to see the entirety of the large variable to know for sure if it's OK because STRDBG tops out at 64K to view variables.
I can update to the latest version as well, if needed but was not sure if that was really needed so I did not do that yet.
Anyone have any insights on what I could do to test or what it could be?
Thanks all!
stefan@tageson.se
Contact:
Re: http_req with POST and large string
Post by stefan@tageson.se »
What is the definition of variable formdata?
belstsrv
Post by belstsrv »
** my program **
D formData        s               a   len(16000000) varying
** HTTPAPI **
D   SendStr                       a   len(16000000) varying const
D                                     options(*varsize:*omit:*nopass)
This matches the same variable in the HTTPAPI.
belstsrv
Post by belstsrv »
I just updated to the latest version of HTTPAPI and it did not correct the issue.
stefan@tageson.se
Contact:
Any hints from the log file?
belstsrv
Post by belstsrv »
Yes, sort of. I had to add logging to this process as we did not have it before. It shows this:
POST /m1auth/v9auth.php HTTP/1.1
Host: authhost.domain.com
User-Agent: http-api/1.45
Content-Type: application/x-www-form-urlencoded
Content-Length: 65654
I can also see the payload for the POST is also truncated. I will not post it due to size but the content length from above indicates it's being truncated someplace, just not sure where.
Thank you for your help as well.
User avatar
tools400
Post by tools400 »
Did you already check the value of SendLen when calling http_persist_req() from http_req()?
And what about wwUplLen when calling do_oper() from http_persist_req().
If these value are correct, I would go further down the chain.
User avatar
tools400
Post by tools400 »
I would also check the first 4 bytes of field 'body', which contain the length of the field:
eval body:x 4
or
eval body:x 32
if you want to see the first data Bytes, too.
belstsrv
Post by belstsrv »
tools400 wrote: Wed Jun 21, 2023 12:58 pm Did you already check the value of SendLen when calling http_persist_req() from http_req()?
SendLen at the call to http_persist_req() from http_req() is 65654
User avatar
tools400
Post by tools400 »
So that makes me believe that your "body" field is not at the expected size. It seems that it contains less data than expected. Please double check that.
You may directly check the length bytes of the "body" field after the statement that fills "formData". And you probably want to check the data of the following fields in procedure http_req():
  • SendStr - should match your "formData" field
  • SendPtr - should be the data pointer of field "SendStr"
  • SendLen - should be the length of field "SendStr" (expected: 65654)
Where to set the breakpoint:
        if sndFd=-1 and %parms >= 6 and %addr(SendStr) <> *null;
           getBufferInfo(SendStr: SendPtr: SendLen );
           sndProc = *null; // add breakpoint and check the values
