REST API authentication issue
kanakag
Post by kanakag »
This is my first experience with HTTPAPI.
We do have a REST API exposed in our ESB to validated Blacklisted customers. ESB services requires API key to access. We have written a Java program to access this REST API and it is mentioned below.
import java.io.BufferedInputStream;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.OutputStream;
import java.io.UnsupportedEncodingException;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.URL;
import java.net.URLEncoder;
import java.nio.charset.StandardCharsets;
import java.security.GeneralSecurityException;
import java.security.cert.CertificateException;
import java.security.cert.X509Certificate;
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import java.util.Date;
import javax.net.ssl.HttpsURLConnection;
import javax.net.ssl.SSLContext;
import javax.net.ssl.TrustManager;
import javax.net.ssl.X509TrustManager;
import org.json.simple.JSONObject;
import org.json.simple.JSONValue;
public class AMLNameScreen {
	public static void main(String[] args) {
		// Create a trust manager that does not validate certificate chains
		//Trust SSL
		TrustManager[] selfTrustManager = new TrustManager[] {
				new X509TrustManager() {
					@Override
					public X509Certificate[] getAcceptedIssuers() {
						return null;
					@Override
					public void checkServerTrusted(X509Certificate[] arg0, String arg1) throws CertificateException {
					@Override
					public void checkClientTrusted(X509Certificate[] arg0, String arg1) throws CertificateException {
		// Install the all-trusting trust manager
		try {
		    SSLContext sc = SSLContext.getInstance("SSL");
		    sc.init(null, selfTrustManager, new java.security.SecureRandom());
		    HttpsURLConnection.setDefaultSSLSocketFactory(sc.getSocketFactory());
			//String query="AccountCategory="+URLEncoder.encode("EXT",StandardCharsets.UTF_8.toString())+"&AccountNumber="+URLEncoder.encode("008000102000001",StandardCharsets.UTF_8.toString());
			URL url=new URL("https://dev.apigateway1.seylan.ad:2260/inquiry/customer/customerscanning/1.0/AMLNameScreening");
			HttpURLConnection conn=(HttpURLConnection)url.openConnection();
			conn.setRequestMethod("POST");
			conn.setRequestProperty("api_key", "CQgeMbtWGFLbwPJSf-FOfxDo");
			conn.setRequestProperty("Content-Type", "application/json");
			conn.setRequestProperty("Accept", "application/json");
			conn.setDoOutput(true);
			Date date = Calendar.getInstance().getTime();
            //DateFormat dateFormat = new SimpleDateFormat("yyyymmddhhmmss");
			DateFormat dateFormat = new SimpleDateFormat("yyyymmddmmss");
            String strDate = dateFormat.format(date);
            String reqId = "EQU"+strDate;
			String inputStr = "{ \r\n"
					+ "  \"AMLNameScrnWS_request\": { \r\n"
					+ "    \"Unique_request_id\": \""+reqId +"\", \r\n"
					+ "    \"Black_List_check\": \"Y\", \r\n"
					+ "    \"Customer_database_check\": \"Y\", \r\n"
					+ "    \"Rejected_list_check\": \"Y\", \r\n"
					+ "    \"Employee_database_check\": \"N\", \r\n"
					+ "    \"Name1\": \"smith\", \r\n"
					+ "    \"Name2\": \"john\", \r\n"
					+ "    \"Name3\": \"\", \r\n"
					+ "    \"Name4\": \"\", \r\n"
					+ "    \"Name5\": \"\", \r\n"
					+ "    \"Dob\": \"01-01-1950\", \r\n"
					+ "    \"Doi\": \"01-01-1950\", \r\n"
					+ "    \"Address\": \"\", \r\n"
					+ "    \"Passport_no\": \"\", \r\n"
					+ "    \"Nic_no\": \"\", \r\n"
					+ "    \"Id_number1\": \"\", \r\n"
					+ "    \"Id_number2\": \"\", \r\n"
					+ "    \"Id_number3\": \"\", \r\n"
					+ "    \"Id_number4\": \"\", \r\n"
					+ "    \"Id_number5\": \"\", \r\n"
					+ "    \"Country1\": \"\", \r\n"
					+ "    \"Country2\": \"\", \r\n"
					+ "    \"Country3\": \"\", \r\n"
					+ "    \"Country4\": \"\", \r\n"
					+ "    \"Country5\": \"\", \r\n"
					+ "    \"Remarks\": \"test transaction 123456\" \r\n"
					+ "  } \r\n"
			OutputStream out=conn.getOutputStream();
			out.write(inputStr.getBytes("utf-8"));
			int response_code=conn.getResponseCode();
			if(response_code!=200) {
				System.out.println("Failed: HTTP Response Code : "+response_code);
				InputStream instr=new BufferedInputStream(conn.getErrorStream());
				BufferedReader reader =new BufferedReader(new InputStreamReader(instr));
				String output="";
				System.out.println("Server output:");
				while ((output=reader.readLine())!=null) {
					System.out.println(output);
			else {
				System.out.println("Success: HTTP Response Code : "+response_code);
				InputStream instr=new BufferedInputStream(conn.getInputStream());
				String output="";
				String wsOutput = "";
					wsOutput = wsOutput.concat(output).trim();
				Object obj = JSONValue.parse(wsOutput);
				JSONObject jsonObject = (JSONObject) obj;
				Object obj_root = jsonObject.get("AMLNameScrnWS_response");
				JSONObject jsonObject_root = (JSONObject) obj_root;
				// Status of the call
				Object obj_status = jsonObject_root.get("Status");
				JSONObject jsonObject_status = (JSONObject) obj_status;
				String status_code = (String)jsonObject_status.get("Code");
				String status_desc = (String)jsonObject_status.get("Description");
				// AML server response
				Object obj_response = jsonObject_root.get("Srv_response");
				JSONObject jsonObject_response = (JSONObject) obj_response;
				String respose_code = (String)jsonObject_response.get("Response");
				// AML server message
				Object obj_message = jsonObject_root.get("Srv_response");
				JSONObject jsonObject_message = (JSONObject) obj_message;
				String respose_msg = (String)jsonObject_message.get("Message");
				System.out.println(status_code);
				System.out.println(status_desc);
				System.out.println(respose_code);
				System.out.println(respose_msg);
		} catch (GeneralSecurityException e) {
			e.printStackTrace();
		} catch (MalformedURLException e) {
		} catch (UnsupportedEncodingException e) {
		} catch (IOException e) {
To achieve the same we have written a sample RPGLE program in order to get connected and validate. The sample RPG code given below.
     h dftactgrp(*no) actgrp(*CALLER) bnddir('HTTPAPI')
     d/copy qrpglesrc,httpapi_h
     d cmd             pr                  extpgm('QCMDEXC')
     d  command                     200a   const
     d  length                       15p 5 const
     d rc              s             10i 0
     d msg             s             52a
     d fromAddr        s            100a   varying
     d Subject         s            100a   varying
     d message         s           1000a   varying
     d myPointer       s               *
     d dataSize        s             10i 0
     d formData        s          32767a   varying
     d op              s             50a
     d userid          s             32a
     d pass            s             32a
     d Url             s            100a
     d reqId           s             10a
     d cust_name       s             30a
     d dob_4_api       s             10a
     d CRLF            c                   const(x'0D25')
      /free
         http_debug(*on: '/Download/my_httpapi_log.txt');
         userid = 'api_key';
         pass = 'CQgeMbtWGFLbwPJSf-FOfxDo';
         formData = ' ';
         reqId = '1245';
         cust_name = 'smith';
         dob_4_api = '19500101';
         http_setauth(HTTP_AUTH_MD5_DIGEST: userid : pass);
         http_setOption( 'content-type'
                       : 'application/json');
         formData = '{"AMLNameScrnWS_request": +
                      {"Unique_request_id": reqId, +
                                        "Black_List_check": "Y", +
                                        "Customer_database_check": "Y", +
                                        "Rejected_list_check": "Y", +
                                        "Employee_database_check": "N", +
                                        "Name1": cust_name, +
                                        "Name2": " ", +
                                        "Name3": " ", +
                                        "Name4": " ", +
                                        "Name5": " ", +
                                        "Dob": dob_4_api, +
                                        "Doi": " ", +
                                        "Address": " ", +
                                        "Passport_no": " ", +
                                        "Nic_no": " ", +
                                        "Id_number1": " ", +
                                        "Id_number2": " ", +
                                        "Id_number3": " ", +
                                        "Id_number4": " ", +
                                        "Id_number5": " ", +
                                        "Country1": " ", +
                                        "Country2": " ", +
                                        "Country3": " ", +
                                        "Country4": " ", +
                                        "Country5": " ", +
                                        "Remarks": "test transaction 123456" +
         Url = 'https://dev.apigateway1.seylan.ad:2260/inquiry/customer/custome+
                rscanning/1.0/AMLNameScreening';
         rc = http_req( 'POST'
                      : %trim(Url)
                      : '/Download/testpost.html'                         // file to receive
                      : *omit                                             // string to receive
                      : *omit                                             // file to send
                      : formData );                                       // string to send
         if rc <> 1;
              msg = http_error();
              dsply msg;
              cmd('DSPF ''/Download/testpost.html''': 200);
Unfortunately, we get authentication failure. We have changed http_setauth to HTTP_AUTH_BASIC and HTTP_AUTH_MD5_DIGEST but none of them are not working. Since we are new to this and we are clueless now. The generated log is given below.
HTTPAPI Ver 1.48 released 2023-09-13
OS/400 Ver V7R3M0
http_setauth(): entered
DNS resolver retry  : 2
DNS default domain: seylan.ad
DNS server found: 10.66.10.11
DNS server found: 10.66.10.12
DNS server found: 10.82.10.11
SNI hostname set to: dev.apigateway1.seylan.ad
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Serial Number: 00:A7:4B:E8:CA:B6:FA:52:0D
Common Name: dev.apigateway1.seylan.ad
Country: LK
State/Province: Western
Locality: Colombo
Org Unit: Seylan Bank PLC
Org: IT-SE
Issuer CN: itse.seylan.ad
Issuer Country: LK
Issuer State/Province: Western
Issuer Locality: Colombo
Issuer Org: Seylan Bank PLC
Issuer Org Unit: IT-SE
Issuer E-Mail: it-se@seylan.lk
Version: 3
not before: 20201010053123
Unknown Field: 05:31:23 10-10-2020
not after: 20301008053123
Unknown Field: 05:31:23 08-10-2030
Unknown Field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
Unknown Field: 2048
Unknown Field: 70D30AD2BBEB74B29B3359D8DD926262
Unknown Field: 3AC443E1F750B0FC7F1F383F5C68E6491C3DA2DC
Unknown Field: 419A5E563C6AF93F3456AA16B5AB2136F3662CD0AFB33B87A034A274E3A47A04
Unknown Field: 15
Unknown Field: dev.apigateway1.seylan.ad
Unknown Field: 0
mkdigest(): entered
POST /inquiry/customer/customerscanning/1.0/AMLNameScreening HTTP/1.1
Host: dev.apigateway1.seylan.ad:2260
User-Agent: http-api/1.48
Content-Length: 549
Authorization: Digest username="api_key", realm="", nonce="", uri="/inquiry/customer/customerscanning/1.0/AMLNameScreening", response="cbce977886835eccae9ee574553b7d01"
{"AMLNameScrnWS_request": {"Unique_request_id": reqId, "Black_List_check": "Y", "Customer_database_check": "Y", "Rejected_list_check": "Y", "Employee_database_check": "N", "Name1": cust_name, "Name2": " ", "Name3": " ", "Name4": " ", "Name5": " ", "Dob": dob_4_api, "Doi": " ", "Address": " ", "Passport_no": " ", "Nic_no": " ", "Id_number1": " ", "Id_number2": " ", "Id_number3": " ", "Id_number4": " ", "Id_number5": " ", "Country1": " ", "Country2": " ", "Country3": " ", "Country4": " ", "Country5": " ", "Remarks": "test transaction 123456" } }
HTTP/1.1 401 Unauthorized
Date: Thu, 30 Nov 2023 02:08:06 GMT
Access-Control-Allow-Methods: GET,PUT,POST,DELETE
Access-Control-Allow-Headers: Content-Type, api_key, Authorization, Accept, DNT, Referer
Access-Control-Allow-Credentials: FALSE
Connection: close
Server: Jetty(9.2.14.v20151106)
SetError() #13: HTTP/1.1 401 Unauthorized
recvresp(): end with 401
recvdoc parms: identity 0
SetError() #36: This page requires a user-id & password
recvdoc(): No content-length: receiving until disconnect
  "ErrorMessage" : "The subscription corresponding to the key apikey is invalid",
  "ErrorCode" : "Invalid Subscription",
  "MoreInfo" : "Policy Name - Verify API Key, Type - VERIFY_API_KEY"
SetError() #44: CommTCP_read: Socket has been shut down.
Kindly help us on how to achieve this based on the java code mentioned above.
Thank you in advance.
Re: REST API authentication issue
I'm not familiar with the Java code. What does this line of code do?
Several other calls to the setRequestProperty method seem to be setting HTTP headers. "api_key" is not a standard HTTP header, though -- but, is that what it's doing? Setting a header named "api_key"? (If so, why the heck is the method called 'set request property' instead of 'set header' that's really confusing.)
At any rate, I don't see any Java code that's setting basic or digest authentication... I can't imagine setRequestProperty does that, does it? Why are you coding basic or digest auth in RPG?
kanakag
Post by kanakag »
Thank you for the prompt reply.
It is for api authentication key. Basically it is a header. Futher, 'SetHeader' method is not available in referred class.
Please refer below cURL command.
curl -H "api_key:STEyBYYIgTIdHqtNnfGGZwsP" -v https://dev.apigateway1.seylan.ad:2260/Inquiry/Account/AccountInquiry/1.0/GetAccountBalance?"AccountCategory=EXT&AccountNumber=003000170015001"
As mentioned in you comment I've added a custom header to the code.
         ctl-opt dftactgrp(*no) actgrp(*CALLER) bnddir('HTTPAPI');
         dcl-pr cmd extpgm('QCMDEXC');
              command char(200) const;
              length packed(15:5) const;
         end-pr;
         dcl-s rc int(10:0);
         dcl-s msg char(52);
         dcl-s fromAddr varchar(100);
         dcl-s Subject varchar(100);
         dcl-s message varchar(1000);
         dcl-s dataSize int(10:0);
         dcl-s formData varchar(32767);
         dcl-s op char(50);
         dcl-s userid char(32);
         dcl-s pass char(32);
         dcl-s Url char(100);
         dcl-s reqId char(10);
         dcl-s cust_name char(30);
         dcl-s dob_4_api char(10);
         dcl-c CRLF const(x'0D25');
         // main coutine
         http_xproc(HTTP_POINT_ADDL_HEADER: %paddr(AddHeaders));
         formData = ' ';
         http_setauth(HTTP_AUTH_NONE: '' : '');
         http_setOption ( 'network-ccsid' : '1208' );
         http_setOption( 'accept'
         formData = '"AccountCategory=EXT+
                      &AccountNumber=003000170015001"';
         Url = 'https://dev.apigateway1.seylan.ad:2260/Inquiry/Account/AccountI+
                nquiry/1.0/GetAccountBalance?'+formData;
         rc = http_req( 'GET'
                      : %trim(Url)
                      : *omit                                             // string to send
         if rc <> 1;
              msg = http_error();
              dsply msg;
         http_xproc(HTTP_POINT_ADDL_HEADER: *NULL);
         dcl-proc AddHeaders;
          dcl-pi *n ;
               ApiKey varchar(32767);
          ApiKey = '"api_key:STEyBYYIgTIdHqtNnfGGZwsP"' + x'0d25';
         end-proc;
Still I'm unable to receive the payload. Please refer below log.
OS/400 Ver V7R3M0
Country: LK
Locality: Colombo
Org: IT-SE
Issuer Country: LK
Version: 3
Unknown Field: 2048
Unknown Field: 15
Unknown Field: 0
do_oper(GET): entered
GET /Inquiry/Account/AccountInquiry/1.0/GetAccountBalance?"Account HTTP/1.1
Accept: application/json
Date: Fri, 01 Dec 2023 07:11:08 GMT
Connection: close
I would suggest removing the extra quotes from the formData and ApiKey variables. These would not be included in either the Java or Curl exxamples. (In Java, the double quote " characters do what the single quote ' characters do in RPG. In curl, they are just used to prevent special characters from being handled by the shell.)
         formData = 'AccountCategory=EXT+
                      &AccountNumber=003000170015001';
ApiKey = 'api_key: STEyBYYIgTIdHqtNnfGGZwsP' + x'0d25';
kanakag
Post by kanakag »
Thank you for the guidance. Now we are able to receive the payload from the API.
Have a wonderful weekend.
