Clarification on - YAJL_OBJECT_FIND
THIYAGARAJAN
Post by THIYAGARAJAN »
Hi Guys,
I am using YAJL_OBJECT_FIND(DocNode: 'String'); to find a node inside a JSON.
If the node is not present then it will return SPP:NULL else an address of the node. My doubt here is - is there a way to validate whether Node is found or not? .
Re: Clarification on - YAJL_OBJECT_FIND
Unless I misunderstand you, you have answered your own question.
YAJL_OBJECT_FIND returns a pointer so one way to test is simply:
node = YAJL_OBJECT_FIND(.....);
if node <> *Null;
   // node is valid
   // node not found
THIYAGARAJAN
Thanks Jon.
