DATA-INTO. missing nodes name
Re: DATA-INTO. missing nodes name
Here's an example of reading the document using the subprocedures... of course, this assumes that my corrections to your format are correct -- if not it may need to be adjusted, but hopefully it gives you the idea of how the "Carrier 1", "Carrier 2", etc can be used as dynamic variable data rather than using hard-coded names like you would in data-into:
ctl-opt dftactgrp(*no) actgrp('KLEMENT') bnddir('YAJL');
/copy YAJL_H
dcl-ds CarrierList qualified;
  num_carrier int(10) inz(0);
  dcl-ds carrier dim(999);
    name    varchar(30);
    id      varchar(6);
    service varchar(15);
  validationErrors varchar(500);
dcl-s docNode      like(YAJL_VAL);
dcl-s errMsg       varchar(500);
dcl-s carriersNode like(YAJL_VAL);
dcl-s i            int(10);
dcl-s count        int(10);
dcl-s key          varchar(50);
dcl-s val          like(YAJL_VAL);
dcl-s msg          char(52);
//  Load the JSON document from the IFS
docNode = yajl_stmf_load_tree('pargent70.json': errMsg);
if docNode = *null;
  // TODO: handle error
// Find the "Carriers" node in the object
carriersNode = yajl_object_find(docNode: 'Carriers');
if carriersNode = *null;
  // Error: There was no "Carriers" node in the object.
  // TODO: Handle error
// Load the list of carriers from the "Carriers" object
// into our data structure.
i = 0;
count = 0;
dow YAJL_OBJECT_LOOP(carriersNode: i: key: val);
  count += 1;
  carrierList.num_carrier = count;
  CarrierList.carrier(count).name = key;
  CarrierList.carrier(count).id = grabString(val: 'CarrierID');
  CarrierList.carrier(count).service = grabString(val: 'CarrierService');
enddo;
//  Read the validationErrors field
carrierList.validationErrors = grabString(docNode: 'ValidationErrors');
//  Free up YAJL resources now that everying has been
//  loaded into the DS
yajl_tree_free(docNode);
//  TODO: This is just to prove that the concept works.
//        Replace with "real" business logic in the
//        finished program.
for i = 1 to carrierList.num_carrier;
  msg = carrierList.carrier(i).name
      + ' id=' + carrierList.carrier(i).id
      + ' srv=' + carrierList.carrier(i).service;
  dsply msg;
endfor;
//   grabString(): Returns a string node from within an object
//                 or '' if the node wasn't found
//    obj = (input) object to locate the key in
//    keyName = (input) key ("field name") of the string
//                    within the json object ("obj")
//   Returns the value of the string, or '' if the string
//     was not found or wasn't a string.
dcl-proc grabString;
  dcl-pi *n varchar(65535);
    obj     like(YAJL_VAL) value;
    keyName varchar(50) const;
  dcl-s result varchar(65535) static;
  dcl-s tempNode like(YAJL_VAL) static;
  tempNode = yajl_object_find(obj: keyName);
  if tempNode = *null;
    result = '';
    result = yajl_get_string(tempNode);
  return result;
end-proc;
pargent70
Post by pargent70 »
This is the real json that I received:
	"Carriers": {
		"Generic": [
				"CarrierID": "3103",
				"CarrierService": "Standard"
		"DHLParcel": [
				"CarrierID": "1392",
				"CarrierService": "Paket DE"
		"BRT": [
				"CarrierID": "3678",
		"PosteDeliveryBusiness": [
				"CarrierID": "384",
		"MyDHL": [
				"CarrierID": "2098",
				"CarrierID": "2099",
	"ValidationErrors": ""
I've solved by :
YAJL_object_find(docNode: 'Carriers');
then YAJL_OBJECT_LOOP and YAJL_ARRAY_LOOP
when the CarrieID match with the carried id that I know,
I retrieve the name of the parent node.
Now I'm continuing the devolopment,
but I will comeback on your code to try to improve mine.
thanks a lot
