DATA-INTO. missing nodes name
I have a json like this, from comeback to external api calling
"Carriers":
{"Carrier1":[
{"CarrierID":"3103",
"CarrierService":"Standard"
"Carrier2":[
{"CarrierID":"1392",
"Carrier3":[
{"CarrierID":"3678",
"Carrier4":[
{"CarrierID":"384",
"Carrier5":[
{"CarrierID":"2098",
{"CarrierID":"2099",
"ValidationErrors":"text message"
I don't know the names of the nodes related to the Carriers ( Carrier1, Carrier2, etc),
until I get the json.
with "path" parameter I overcome the problem about the missing json root name,
but then, how can I define the DS to be used in the DATA-INTO?
"Carriers":
{"Carrier1":[
"Carrier2":[
"Carrier3":[
"Carrier4":[
{"CarrierID":"384",
"Carrier5":[
Re: DATA-INTO. missing nodes name
Unfortunately, you really can't use variable names with DATA-INTO, because RPG needs to know the names at compile-time.
If there's a limited number of them, you could hard-code all of them into your data structure, and make them all optional, then only the appropriate ones would be filled in.
However, if you want it to be truly dynamic, you shouldn't use DATA-INTO. Instead, use the YAJL subprocedures, they will allow you to make it completely dynamic.
If you are able to influence the design of this JSON document, I would submit that this isn't a very good design. The field names should identify WHAT something is, they should not be used for data. Using the field names to identify a given carrier violates that design rule, and makes it more difficult to interpret the document -- it is not a good design. But, if you aren't involved in the design process, and must simply use a document that is already in place, then go with the YAJL subprocedures.
Thanks Scott.
right now I'm not able to ask for a change format.
with Php I already did a script to work with this json,
maybe I will do something to store the nodes name on a table
and then use this to create something to reuse on rpgle
Hmm... not sure how it helps to have the node's name in a table. Just read it from the JSON document... can't do that with DATA-INTO, but you can with the YAJL subprocedures.
The idea could be to Read this table and work with path parameter for each node
So I can use data-into for little portion of json
I have to try, tomorrow
Thanks again
Thanks again
So you're going to use a separate call to data-into for every node you need? And then someone is going to populate the table with the name of those nodes?
Seems like a lot of extra work and a very inneficient program. What would be the advantage of doing it this way?
I already tried with YAJL subprocedures with no result.
I will try again, maybe I did mistakes...
You right, my Solution is not efficient,
I reserve it as last chance
peder udesen
Perhaps you can do it by coding a handler for Rational Open Access
using "Handling input data using name-value information"
Check it here:
https://www.ibm.com/docs/en/i/7.4?topic ... input-data
Check it here:
I'm struggling to see how that helps, unless the individual "carrier" names correspond to the names of externally defined fields? Then it might help because the OA handler would hand you the field names... but they'd still have to be known when you compile the calling RPG program, because that's just how external definitions work in RPG, they're compiled in.peder udesen wrote: Wed Aug 31, 2022 8:40 am Perhaps you can do it by coding a handler for Rational Open Access
Within the OA handler code, you'd still have to call the YAJL procedures (or a similar set of JSON routines) so I don't really see how this saves you anything?
Looking more closely at your example document -- it's not valid JSON. There are many places where you try to put an object key name inside an array (rather than an object.) And places where you start an array and an object, but then close only the array and not the object, leading to a lot of errors within the document. No JSON parser can read the document you posted.
I'm assuming that you typed that document off the top of your head (rather than copy/paste) and what you really meant was a document like this:
"Carriers": {
"Carrier1": {
"CarrierID": "3103",
"CarrierService": "Standard"
"Carrier2": {
"CarrierID": "1392",
"Carrier3": {
"CarrierID": "3678",
"Carrier4": {
"CarrierID": "384",
"Carrier5": {
"CarrierID": "2098",
"Carrier6": {
"CarrierID": "2099",
"ValidationErrors": "text message"
