I think perhaps I didn't explain well enough: I want to reproduce the problem so I can fix it. I can't reproduce it with a file that doesn't cause errors... Neither of the files you provided cause errors.
That said, I understand the problem now because of your comments about how you can't upload more than 256K. As we've already noted, it's failing on an %ALLOC BIF. This function can only reserve memory for up to 16 mb of data... you said your file was 32mb, and therefore it cannot possibly handle it.
I will change YAJLINTO to use Teraspace allocations instead of %ALLOC -- that will allow for much larger data sizes.
YAJLINTO returns %error and %status 00359
sLucke1015
Re: YAJLINTO returns %error and %status 00359
That is awesome!
As some of my grandchildren would say, You are The Bomb!
I will keep an eye out for the updated YAJLINTO.
Thank you very much, Sir!
Please try the newest version on my website: https://www.scottklement.com/yajl/
I tested it with a 94 mb JSON. It failed prior to the update, but worked fine after. Make sure iy works for you.
sLucke1015
YAJL update installed and we are now processing documents large and small.
Thanks again Scott!!!
