return code -1
eric@negsys
Re: return code -1
Post by eric@negsys »
Thanks for your quick answer and your help.
I need to ask my client for permission because you will log into his system. If he agrees, I will send you a library with the files and the programs.
Very important :
I will give you the same program as we run on our system and we never had the problem. This problem only happens on their system
So I hoppe you will reproduce the problem
Re: return code -1
eric@negsys wrote: Wed Sep 27, 2023 1:51 pm Thanks for your quick answer and your help.
Very important :
Hi Eric,
I think asking me to log onto someone else's system and troubleshoot a problem that only occurs on one computer is asking too much for free, public, forum-based support.
If you can send me a program that I can load/run on my system that reproduces the problem, I will look into it.
The other alternative is to hire me at an hourly consulting rate.
eric@negsys
Re: return code -1
I’m sorry but our client refuses to give permission for an external connection. We will never know where the problem comes from, perhaps related to a PTF not installed...
To get around the problem, we asked them to fill out a table directly on the AS400, and then we do our processing.
The subject can be closed. Thanks for your help.
