Hi Scott, we are getting the error 6000 CPDBC97 GSK_OS400_ERROR_NOT_TRUSTED_ROOT. We have been working fine until a week or two ago. IBM says it is a certificate error, but we have all the correct certs installed and so not sure what has changed.
Information below from IBM ticket I opened
The certificate exchange fails with error code 6000
Does the HTTPAPI client use the DCM *system store?
Do you have the below CA certificates installed to DCM?
Secure Socket API Error Code Messages
https://www.ibm.com/support/pages/node/639467
remote web service endpoint.
https://secure.shippingapis.com/Shippin ... Request%3E
httpapi_debug.txt
HTTPAPI Ver 1.41 released 2020-06-05
OS/400 Ver V7R4M0
https_init(): entered
QSSLPCL = *OPSYS
initializing GSK environment
SNI hostname set to: secure.shippingapis.com
Cert Validation Code = 6000
POST /ShippingAPI.dll?API=TrackV2&XML=<TrackRequest%20USERID="765COACH7405"><TrackID%20ID="9261290290704506332556"></TrackID></TrackRequest> HTTP/1.1
Host: secure.shippingapis.com
User-Agent: http-api/1.41
Content-Type: application/xml
Content-Length: 400000
.senddoc(): entered
<TrackRequest USERID="765COACH7405"><TrackID ID="9261290290704506332556"></TrackID></TrackRequest>
HTTP/1.1 302 Moved Temporarily
Date: Mon, 14 Feb 2022 23:26:47 GMT
Connection: close
Via: HTTPS/1.1 localhost.localdomain
Location: http://172.27.109.85:15871/cgi-bin/bloc ... 3341558858
Content-Length: 0
CA certificates needed by a pc browser client, or IBM i client:
DigiCert Global Root CA
GeoTrust TLS DV RSA Mixed SHA256 2020 CA-1
Re: GSK_OS400_ERROR_NOT_TRUSTED_ROOT
I'm not sure what you are asking. You clearly already know what the problem is, you have an untrusted root certificate. Why not just fix it?
What's the point of posting a trace log that doesn't show any errors?
