Mystery cookie cache
jtaylor
Post by jtaylor »
I have a *SRVPGM that downloads PDF files from an Azure environment. The environment requires no authentication. The code hasn't changed in months or years. Starting Sunday morning, one particular user starting getting HTTP 403 responses. All other users continue to function, even downloading PDF files from the same URLs. Our IT department, who's responsible for the Azure environment, swears nothing has changed.
I updated HTTPAPI (1.32 -> 1.45), but the issue persisted (I figured it couldn't hurt to get current). I set http_debug() and compared logs between the problem user and other users. Cookies are the one thing that jumps out at me. This process shouldn't be using cookies. The problem user shows this:
http_persist_get(): entered
do_oper(GET): entered
There are 1 cookies in the cache
cookie=siteDC not sent (wrong path or domain)
This shows up on the first call within the job, so I don't know where the cached cookies are coming from. As I understand the code, unless an IFS file is specified for caching, cookies are stored in the activation group.
While working users all show:
I can turn off cookies and see what happens, but I don't like leaving things like this hanging.
Any ideas on what to check?
TIA
jtaylor
Re: Mystery cookie cache
Post by jtaylor »
I explicitly turned off cookies, but the underlying issue persists. The cookies may be another symptom of the actual issue or a red herring.
Here's the actual procedure call:
rc = http_url_get(lFileURL :lPdf);
The log for the failing user shows Authorization, which shouldn't be there.
GET url_path_here HTTP/1.1
Host: hostname_here
User-Agent: http-api/1.45
Authorization: Basic ...
HTTP/1.1 403 Server failed to authenticate the request. Make sure the value of Authorization header is formed correctly including the signature.
Here's the sample snippet from a working user:
Host: hostname_here
This has been working for about a year before inexplicably breaking Sunday morning.
I'm not understand what this has to do with cookies?
His userid/password isn't being accepted by the server.
Also, please note that you just posted his userid/password to a public web page, viewable by everyone in the world. I guess its fine in this situation since that userid/password doesn't work, anyway? But, I would definitely make sure its changed -- since you just posted it to the public, anyone/everyone could have it.
jtaylor
Post by jtaylor »
There shouldn't be cookies, and the problem user showed cookies in the log. That's why I started off looking at the cookies.
There shouldn't be any authentication, so I don't know what it's doing there. The program doesn't specify any authentication, so where would the credentials come from?
Edit:
I decoded the credentials and found them in a seemingly unrelated *SRVPGM, which was not setting HTTP_AUTH_NONE. I changed the password and added HTTP_AUTH_NONE in On-Exit.
Thank you so much
Did removing the credentials solve the problem for you?
