Using DATA-GEN + YAJLDTAGEN for iterative build
I know I could do this by simply nesting the structures, but I am trying to use the iterative build feature for cases where the array size exceeds RPG's capabilities. Problem is no matter how I try to structure it the resulting JSON is always "close but no cigar". I have these two DS;
Dcl-ds  orderHeader  Inz;
   CustomerName     varchar(40);
   CustomerId       char(6);
   name_PO_Number   char(9) inz('PO Number');
   PO_Number        varchar(20);
   DueDate          date(*USA);
End-ds;
Dcl-ds  detailLine;
  itemCode  char(8);
  quantity  int(5);
  price     packed(5:2);
End-ds;
And what I want to produce is something like this:
    "CustomerName": "",
    "CustomerId": "",
    "PO Number": "",
    "DueDate": "03/30/2022",
    "Details": [
            "itemCode": "Item-1",
            "quantity": 1,
            "price": 0.60
        repeat items ad naseum
No matter what combo of DATA-GEN I try the best I can get so far is this:
    "CustomerName": "",
    "CustomerId": "",
    "PO Number": "",
}  <<< this close not wanted ...
[  <<< this array needs a key
        "quantity": 1,
        "price": 0.60
I'm guessing that between YAJLDTAGEN and DATA-GEN there is not a combination that will work. Is there any kind of JSON document that can be built iteratively ? I can't think of anything right now but since I know Scott would have tested the capability I feel I am just missing something.
Re: Using DATA-GEN + YAJLDTAGEN for iterative build
Unfortunately, there really isn't a way to do that.
DATA-GEN passes an RPG variable, and YAJLDTAGEN converts that variable to JSON format.
If you think about what you're trying to output -- you're trying to output "part of" a variable. The top of your document is this:
{               <-- this is a "data structure"
    "CustomerName": "",
    "CustomerId": "",
    "PO Number": "",
    "Details": [ <-- this is an array
So you are asking DATA-GEN to pass just "part of" a data structure, and part of an array. This just isn't how DATA-GEN works, it always passes an entire variable.
Using the YAJL subprocedures you could do it easily.
So effectively the iterative build option is just not usable with YAJLDTAGEN at all then? Or can you think of a case that works?
There are two different things I can think of that might be referred to as an "interative build". I'm assuming you mean sequences where you do *START and *END, right?
You can use sequences with YAJLDTAGEN provided that the top-level element is an array or an object, and that each sub-element is added directly to that array or object (rather than being nested deeper into it.)
Take a look at the sequences stuff in the following slides https://www.scottklement.com/presentati ... TA-GEN.pdf -- the part about sequences begins at slide 24.
Thanks Scott - I could have sworn that I had tried that but I guess not.
I'll play with it some more and tease out the limits.
Thanks again.
