hello, im very new to rpg, i just started using it about 2 weeks
i tried to recreate an example http-post program in my own library. i also follow the step in this video https://youtu.be/N9NqeBEGJcA
but when i compile the program,i got these errors:
"Errors were found during the binding step. See the job log for more information."
"Program 'program name' in library 'libname' not created."
how can i fix this?
thank you for any help
Error while compiling program
Re: Error while compiling program
Take a look at the job log. After your compile command there will be a list of errors that occurred. What are they?
it says, binding directory HTTPAPI in library *LIBL not found, how can i fix that?
i also tried
Build & run the install program:
CHGCURLIB CURLIB(LIBHTTP)
CRTCLPGM INSTALL SRCFILE(LIBHTTP/QCLSRC)
CALL INSTALL
and the job log return error "Not authorized to process request on member CONFIG_H."
but i still can make a run of example program with "call libhttp/example4"
i also tried
CALL INSTALL
The message is telling you that LIBHTTP is not in your library list. So the simple solution is to add it.
ADDLIBLE LIBHTTP
Then try the compile again.
The binding directory HTTPAPI is used to allow the compiler to find all of the service routines needed by HTTPAPI. On the H spec or Ctl-Opt at the start of your program you probably have BNDDIR(HTTPAPI) specified. That is the easiest way to ensure that the compiler can find what int needs.
ADDLIBLE LIBHTTP
See Jon's response -- you need to add it to your library list.maulsays wrote: Sat Apr 16, 2022 9:44 pm it says, binding directory HTTPAPI in library *LIBL not found, how can i fix that?
Advice: I have taught a lot of people who are new to the platform, and library list is one of the concepts that people struggle with the most. Take some time, ask an experienced co-worker to spend some time with you, and make sure you get a good grasp on it. This will be a huge help when using this platform, because the library list is used just about everywhere.
This means that you don't have enough authority/permission to update the HTTPAPI configuration. My guess is that you only have read authority (*USE) to the file and not write authority (*CHANGE). That said, I wonder if you need to run this program? Which brings me to your next question:maulsays wrote: Sat Apr 16, 2022 9:44 pm and the job log return error "Not authorized to process request on member CONFIG_H."
The fact that this works when the call to INSTALL received an error implies to me that someone has already run INSTALL on your system, and it is already set up and configured for your environment. Is that true? If so, you shouldn't need to run it again.maulsays wrote: Sat Apr 16, 2022 9:44 pm but i still can make a run of example program with "call libhttp/example4"
The main thing is the library list. See Jon's post about how to resolve it.
works perfectly. thank you for your help and expalanationjonboy49 wrote: Sat Apr 16, 2022 11:03 pm The message is telling you that LIBHTTP is not in your library list. So the simple solution is to add it.
ADDLIBLE LIBHTTP
thankyou for the insight and explanation. i already try jon post and it workScott Klement wrote: Sun Apr 17, 2022 1:15 amSee Jon's response -- you need to add it to your library list.maulsays wrote: Sat Apr 16, 2022 9:44 pm it says, binding directory HTTPAPI in library *LIBL not found, how can i fix that?
again, thank you for helping me with this noob question. have a nice day
