I'm trying to send a token using HTTP_POINT_ADDL_HEADER but I'm receiving an error. I've updated LIBHTTP to the latest version & recompiled the programs to be on the safe side. I've looked in examples here but still can't it it to work. What am I missing?
Any help is much appreciated.
Here are snippets of my code
http_setOption( 'content-type'
: 'application/json' );
: %paddr(SetToken));
rc = http_req( 'POST'
: 'https://stgapi.freightclub.com/Rate/GetRates'
: results
: *omit
: jsonfil
: *omit);
p SetToken b
D SetToken pi
D HeaderData 32767a varying
D CRLF C CONST(x'0d25')
D tokentype c CONST('Bearer')
D tokenvalue c CONST('SoVz-20qajzR3l2Dt-PxeOS04hJ3q') This is only part of the token. The token is around 720 characters.
HeaderData = 'Authorization: ' +
tokentype + ' ' + tokenvalue + CRLF;
/end-free
p SetToken e
sending token
kundenancy@gmail.com
Re: sending token
I forgot to post the error
OS/400 Ver V7R1M0
DNS resolver retry : 2
DNS default domain: work.com
DNS server found: 172.30.0.2
DNS server found: 172.16.1.2
https_init(): entered
QSSLPCL = *OPSYS
Support for TLS 1.3 unavailable.
initializing GSK environment
GSK Environment now available
SNI hostname set to: stgapi.freightclub.com
ssl_error(415): (GSKit) Peer not recognized or badly formatted message received.
SetError() #30: SSL Handshake: (GSKit) Peer not recognized or badly formatted message received.
OS/400 Ver V7R1M0
QSSLPCL = *OPSYS
Re: sending token
HTTPAPI uses the operating system's built-in support for TLS (formerly known as "SSL") by calling a set of routines called the IBM Global Secure Toolkit (GSKit).
I see that you are running OS version V7R1. This is an older operating system that IBM no longer supports. Unfortunately, it was never updated with newer TLS versions or cryptographic ciphers.
You should use a tool like a web browser or OpenSSL to connect to the server and see which TLS versions and ciphers it supports, then compare to see what's available on your copy of the operating system. In my experience, this type of problem is very common with V7R1. Cryptography and security change frequently, so continuing to use old, unsupported operating system versions doesn't work well.
V7R1 did not support the current (1.3) version of TLS. It technically did support TLS 1.2, but there was such a limited range of ciphers, that it usually wouldn't work with modern servers. So you would need to ensure that the server you connect to supports TLS 1.1 or older, which is unusual today as it is no longer considered secure.
Re: sending token
The error you posted isn't related to the authorization token.
