Timeout occurred while trying to connect to server!
KKT
Post by KKT »
I am using HTTPAPI Ver 1.42 released 2020-10-12 .
We have a requirement where we need to post information to Azure. For this we are using http_response, also there is an x-functions-key that needs to be passed to connect to server. I am not able to connect to the server getting "Timeout occurred while trying to connect to server! " error. Please find below the code snippet.
Could you please tell me where I am going wrong?
http_debug(*On: '/tmp/httpdebug.txt');
http_xproc( HTTP_POINT_ADDL_HEADER : %paddr(addSpecialHeaders) );
Monitor;
http_response = http_string('POST':Url:P1data:'application/json');
On-Error;
errorMsg = http_error( xErrorNo );
http_comp('Error! xErrorNo: ' + %char(xErrorNo) +
' errorMsg: ' + errorMsg );
EndMon;
PaddSpecialHeaders...
P B
DaddSpecialHeaders...
D PI
D headersToAdd 32767a varying
headersToAdd = 'x-functions-key:' + 'uniquekey'
+ CRLF ;
Return;
P E
Error-log:
OS/400 Ver V7R3M0
DNS resolver retry : 2
DNS default domain: XXX.COM
DNS server found: 10.250.1.1
DNS server found: 10.250.2.2
DNS server found: 10.178.200.20
SetError() #7: Timeout occurred while trying to connect to server!
Re: Timeout occurred while trying to connect to server!
It is unable to connect.
The most common reason would be that there is a firewall blocking you from connecting out to the Internet.
KKT
Post by KKT »
Thanks for your response. Because of that we were finally able to figure out that there was a firewall blocking both from IBM and Azure end. Finally we were able to establish the connection.
