First of all let me thank scott for the.awesome tool. I have a project where i need to use a REST API process to send information to 3M for their GPCS product. It first needs an authorization request made and the return is an JWT. Using this token a following request is to be made with a JSON file as input to the webservice .The response would be another JSOn doc. Is this possible using the tool. Any sample code available?
Thanks for your help
Suresh
HTTPAPI help
Re: HTTPAPI help
It sounds like it should work? No, I don't have an example.
