Currently using native RPG to send / receive data through socket from server.
But now we need to use TLS, Does anyone has sample program ?.
There is sample program from IBM, but in C language.
https://www.ibm.com/docs/en/i/7.3?topic ... y-kit-apis
I just read the COMMSSLR4 and try to use http_select_commdriver.
And trying to rewrite the above C program to RPG
regards
Running Socket over TLS
Re: Running Socket over TLS
Thanks.
And I am studying your service program HTTPAPI
Can I use https_init to replace those below, (as in Figure 1 in your PDF) ?
- gsk_environment_open
- gsk_attribute_set_buffer
- gsk_environment_close
- gsk_attribute_set_enum
Then create the socket connection by "socket" afterwards.
- by CommTcp_ConnectNonBlock
Regards
Thanks.
Regards
From COMMSSLR4, I think CommSSL_Connect in HTTPAPI can be used as your figure 3 in PDF
How about some function CommSSL_.... can be use as figure 2 , 4 and 5 ?
Regards
Regards
