Apache POI 3.6 - Help with RowShift
jmaple79
Post by jmaple79 »
I am just coming back to RPGLE after a long stint away from development so I am rusty (like 10 years of rust). Apache POI and java are brand new concepts to my new company and I was selected to learn them for us. So far it has been fun but I am stuck at the moment and it is probably just lack of a basic understanding that has me caught.
I am trying to use the RowShift method in the HSSFSheet class, but I keep hitting a wall. the error is
Cause . . . . . : RPG procedure INSROWTEST in program POI36/INSROWTEST
received Java exception "java.lang.NoSuchMethodError:
org/apache/poi/hssf/usermodel/HSSFSheet.shiftRows(III)Lorg/apache/poi/h"
when calling method "shif" with signature "" in class
"org.apache.poi.hssf.usermodel.HSSFSheet". ...
Classpaths are correct and tested with the included example code provided in Scott's latest HSSF36 pack
I have defined the method
D RowShift...
 D                 PR              O   Class(*java
 D                                     : HSSF_SHEET_CLASS)
 D                                     ExtProc(*java
 D                                     : 'ShiftRows')
 D   StartRow                          like(jint) value
 D   EndRow                            like(jint) value
 D   RowQty                            like(jint) value
 D
usage in the program
RowShift(Sheet: RowCount: RowAdd: RowQty);
 // RowShift=new_XSSFRowshift(firstrow :lastRow :rowqty);
 SSSheet_createRow(sheet: Rowcount);
   hssf_save(book: IFSDIR + '/test1.xlsx');
Everything else is stock Hssf36 package
I understand this is probably a basic lack of understanding.
jmaple79
Re: Apache POI 3.6 - Help with RowShift
Post by jmaple79 »
I have got to stop answering my own questions AFTER asking a group of peers.
The answer was, I needed to remove the 'Class' statement in the definition blow as well are the 'O'.
SMH. lol
:lol: :roll:
They say talking to yourself is a sign of high intelligence :)
jmaple79
Post by jmaple79 »
My wife may have a differing opinion. :lol:
jmaple79
Post by jmaple79 »
New question....Old topic this time I am stumped
I am trying to shift rows down in a spreadsheet to insert a new row.
Overall goal -
Using existing Template Spreadsheet. Recreate an account monthly customer statement in Excel from the iseries.
Create an account statement by inserting detail records in the middle of a predesigned excel statement.
How can I accomplish this without clearing a row? What am I missing with this?
RowCount = 11;
RowAdd   = RowCount + 16;
RowQty   = 1;
I think what i am doing is shifting everything from row 11 to the end of the sheet down one row and writing a new row in the void created.
I attached a couple pics showing what it is actually doing.
Jason
What I actually wanted
What is is actually doing
Template Rows
Template Rows
msddcb
Post by msddcb »
While this response is not going to help you with RowShift my comment is WHY?
We provide transaction lists in Excel for clients and we just generate a new spreadsheet as required.
Is there a problem that the previous data is not available ?
If data is available why complicate the process ?
There may be reasons why you want to update an existing excel as opposed to creating a new one so apologies if this is the case.
Cheers
jmaple79
Post by jmaple79 »
Fair question. Maybe I am not thinking correctly on this. My thought process revolved around all the existing formatting in the spreadsheet to match the original PDF version of the statement. I thought, if I could simply fill in some details, it would cut down on complexity since we are brand new to Java let alone Apache POI. I could be wrong.
Unfortunately, I have not used RowShift. (That's why there wasn't prototypes for it in the HSSF download.) Doing a quick Google, I can see that there is both the RowShift routine that you pointed to, as well as a whole class called "RowShifter", the docs seem to say that the RowShifter class is a utility that's needed because the process of shifting rows requires calling a bunch of routines that are scattered around.
I have no experience with this (so I may be completely off-base, but..) is it possible that's why RowShift isn't working for you? It requires more than just this one call, but also requires a few more things? You could consider the RowShifter class instead.
jmaple79
Post by jmaple79 »
I'll try that. I am not real confident with this yet, so i hope you all don't mind me bugging you with it as i get stuck.
jmaple79
Post by jmaple79 »
Update*
Rowshift works as expected, when you are using the correct file type. :oops:
I switched to using a .xls file and everything clicked.
Jason
